Fuel consumption
38 minutes ago, D.FYLAKTOS said:
Ricer car is the term in english (slang).
Rightly or wrongly, this would only normally apply to Japanese cars.
  • Replies 88
  • Views 14.3k
  • Don't rely 100% on the charts even the capacity of the tank isn't exactly 42 litres. Every gas station has different inclination, different employee with diferent attitude so there is no quarante
  • 16V sticker on an old 8 valve car, turbo sticker or turbo sound devices on the tail pipe, GTi stickers, plastic discs as rear brake disks etc.
  • Well, there was one Trabant I saw in Germany that had stick-on lettering reading "Trabi Twin Turbo 16 Valve Water Injection", which only just fitted between the rear lights!
29 minutes ago, KenONeill said:
In English we call that a "shopping list" (of stuff you'd like to buy and fit but haven't).
This is me with the OEM accessories book for the Mk1 Fabia... :D
As far as I remember this started as Americans calling Japanese cars, I'd guess because generally the Japanese cars were so much better built than American cars (and UK and European cars) and old memories of Pearl Harbour.
At the 70's-80's i remember that the taxi drivers at the downhill or in the highway they put the Neutral for few seconds and the car was rolling with his own speed, that was a trick of that era for gas economy.
This did/does reduce the control of the car and could mean delayed and fumbled reactions to getting back into gear for emergency braking or acceleration plus it confuses ECUs on modern cars and would use more rather than saving fuel.
In the 1990s in the UK there was a desperate need by some to have the letter 'i' included in the boot badge, 'i' was for injection.  The sales rep (travelling commercial company sales representatives) types that were all about self-image (many times over substance) were particularly concerned about the letters in a boot badge.
The term in Greek for such exaggerations "for show off" in every sector was for over a century (and some times still is) the "Gyfties" which means "Gypsie thing".
I spoke for old cars with 4 gears and carburator.
I have seen it numerus times when i was kid and even today some drivers with 50cc motorcycles use it. From 3rd gear turn to N let the motorcycle roll to a downhill or a boulevard and one click before the traffic light they press and engage again the 3rd gear.
Not sure about modern bikes with oil injection, but older two strokes with oil-petrol mix couldn't use engine brake, as carburettor couldn't provide enough oil. Two stroke cars even had one way bearing to disconnect the engine.
In carburettor engines this did save fuel, as they usually didn't have any way to cut off fuel when engine was driven beyond idle rpm with no gas (although I've seen some DIYs for Estelle to implement that system)
Older ECUs didn't mind, newer usually know which gear is selected, plus I've read somewhere, that some modern engines keep injecting some fuel to keep catalytic converter warm.
Having to help find the correct connectors that were only used for an early 1990s Ford ECU I was surprised to learn that Ford had ECUs going back to IIRC 1981 or 1982 with IIRC (?)their race engines.  Northampton was the base of Cosworth Engineering that Ford were tied in with for a good while.
No only at low rpm felly fuel cut off happens at 1400ish
I was talking about some more modern, like VW's TSI :) Engines that also "dump" fuel to exhaust to not overheat turbo and converter at high loads :D
In felly, there's some hysteresis - you need around 2000RPM to initiate cutoff, but then it can go to 1500ish before it starts again. Not sure why it's programmed that way.
Edited by Papez
 Yes as an old 2 stroke rider i agree plus that was an "ace" for them when they racing against 4 stroke bikes because those in downshift a small bounche on the rear wheel.
In my TC-6 with 3-4-5th gear on when i release the acceleration pedal and let the car roll i see 00 on the lcd.
For me it will initiate it at 1600rpm at a high grade incline and it will start back again at 1400ish. Also the fuel cut is abrupt.
Also clutching the car just before it reinstates fuel will cause the rpm to bog down below idle
Edited by Thefeliciahacker
It is a ECU firmware design problem. Compared to modern vehicles, the fuel cutoff on Felicia is not adaptable enough.
We should be glad it even has it
