Interior Lighting
Hi guys,
I hope you can answer a few questions for me!
I read through the forums trying to find the interior bulbs I need and as a result I've ordered the SuperSkoda Mega Boot Lights, Door Safety Lights and a w5w LED for the glove box.
Can you tell me what bulbs I require for the footwell lights and the ceiling lights (front and rear).
Thank you in advance!
Matt
Footwell lights are W5W's
Not sure about the ones in the roof but they are usually W5W's as well.
Thanks Gizmo!
Just to confirm the footwell are the same as the glovebox and the housing is the same?
Yes they are the same.
They may have a metal casing on the back of them, if so this will prise of with a screwdriver.
BTW welcome!
Many Thanks for both the information and the welcome!
Are most can bus led's dimable?
Not sure but the ones I have fitted can be dimmed via Columbus.
On a side note, I purchased the Superb III - MEGA POWER LED door safety lights WHITE/WHITE - KI-R from SuperSkoda but I cant seem to fit them.
The power connector housing on the original is offset to the left whereas the SuperSkoda connector is centered causing it the hit the bottom of the door storage area.  Can anyone shed some light (sorry) on how to fit or is it possible Ive been supplied with the wrong assembly?
Thank you in advance,
Matt
On my L&K - the footwell lights factory fitted are LED. I just checked them once again. You can try ordering OEM ones - for this purpose - instead of W5W aftermarket.
Edited by simichoil
Ugh,  Ignore the above, I obviously didn't pay enough attention when removing the original cluster.
Issue resolved!!
  • 3 years later...
Can anyone help to provide instructions on how to open the interior light cover above the drive, with map lights, rear light controls on a skoda superb 3 2016. I'm worried I might snap something. Thanks
