David's Citigo 2.0
7 hours ago, pip_vrs said:
Bet that base weighs more than the car :D at least its low down
Whats leaked in your arch?
It is rather heavy :D the shock had a meltdown and ****ed oil everywhere :dull:
  • Replies 294
  • Views 103.5k
  • Exhaust vid for your ears to enjoy -     I realise it's probably to loud for some, but they did do a dB reading for me static at 3800 RPM and it read 89 so I don't think it's too loud if you wi
  • Footage from yesterday at Bedford trying to shake a Saxo off my tail
  • Big thanks to andsoutham for getting my brake pads the right way round tonight Also shiny things Sent from my SM-G920F using Tapatalk
Replaced the tow strap today, had limited options but managed to find a pretty decent one that also stated on the site it was MSA approved, looks pretty solid so if I ever need yanking off track it should do the job. Only downside is the webbing is much longer than the old one, so I can't tuck it out of sight, best I could do was cable tie it over itself, but didn't have any black cable ties.
Edited by Hyphons
Finally got the suspension sorted with thank to @Updown789
I still have a knock though coming from drivers side and it seems I have some very slight play in the driveshaft so I shall get that booked in, checked and replaced if need be.
I've had another look over the car today, knocks when turning side to side but it can't be steering rack as it doesn't make the same noises off the floor, in fact it makes no noise off the floor at all, only when there's load on the front end, only sign I can see of anything being unnormal is the grease on the inner drivers CV boot, so it's booked in Monday morning for a diagnosis and replacement driveshaft if need be, as may as well replace it all whilst it's off
Looks like the knocking is here to stay, it's being caused by the top mounts, kinda adds up, transitioning left to right changes where the sound comes from, also up in the air with no weight over the front there's no noise either. When you Google about Poly top mount knocking it seems a common thing.
It shouldn't knock though? Surely they're either knackered or they're not tight enough.
Were they done up with a proper windy gun?
Brand new shocks so shouldn't be knackered already, I would imagine that if it was because something isn't tight it would be pretty obvious? Plenty have mentioned similar problems, top mounts are from a Golf as well and not a Citigo, but they are exactly same, also the only Citigo as far as I am aware that runs poly top mounts, so no other car to compare too. I'll find out what they said it was when I get home.
Topmounts need to be tight tight.
the lock nit on the top can seem tight but if not dont up properly will cause knocking.
Indeed I normally gun them up off the floor then again when under it's own weight to make sure
It's difficult to get a gun on these, you need to hold an Alan key to stop the strut from spinning whilst doing them up, there's 2 nuts, one to hold the spring, one to attach to strut tower at the top, the one holding the spring was gunned @Updown789 did the work, so we can blame him :D
@Updown789, you need to have a word with David's mum about this attitude, he's totally ungrateful and it's time something is done about it!
Absolutely disgraceful behaviour David. Yes they were definitely done up tight.
In more important news get yourself along to the rolling road day I'm doing week Saturday :)
Already one booked for October ;)
On 7/22/2017 at 17:11, Hyphons said:
Replaced the loser strap today, had limited options but managed to find a pretty decent one that also stated on the site it was MSA approved, my penis looks pretty solid so if I ever need yanking off I'm sure a friend will be there for me and give me a quick blow  job. Only downside is the webbing is much longer than the old one, so I can't tuck my willy out of site, best I could do was cable tie it over itself, but didn't have any black cable ties and I wasn't up for that sort of deviance.
Dirty git.
11 minutes ago, Lee01 said:
Dirty git.
Post duly edited, thanks for pointing out the spelling mistake :D
Car is looking wicked.
where did you get the intake from?
eBay :) standard intake duct from there and the intake from radioworld, hacked up to fit under the bonnet.
Big update today, wheels changed from the Snowflakes to Ultralite F1 wheels
Also had a steady flow of parts arriving for the brakes, including these..
I currently own a citigo sport, and unsure whether to modify it.
Can you give me the best performance and aesthetic mods from your experience? Or would you recommend to leave standard.
Liking the new wheels mate. Suit it well
Only just spotted this, modifying it is entirely up to you, it depends how long you plan on keeping the car etc. there is lots of small mods you can do that can often make big changes, the interior light upgrade, led DRL bulbs, the cherry centre console and so on
Brake upgrade part 2 thanks to the help of @andsoutham
Grooved discs and EBC yellow, along with a brake fluid flush as the brakes had a bit of a moment at Cadwell and it was due in a few thousand miles anyway.
The clearance between the caliper and the wheel is ridiculous, I could get a sheet of paper between the gap and no more..
Just given the thread a good going over and tidied it up, replaced deleted images (thanks to Photo****et screwing them up) and tidied up the original post.
Today's addition, lower front strut brace.
Just about visible from the side
Also put fresh oil and new sparks in the car as well. Thanks again to @Updown789 for his assistance.
Where did you get the lower strut brace from? Looks like an easy fit..... ;)
