key replacement
I need  two replacement key, only got one key from seller or
(Complete lock and key set Skoda Octavia 1997 - 04 1U0800375A New Genuine Skoda)
I need  two replacement key, only got one keys from seller or
You can buy a brand new from ebay. Then you need someone to pair it with Vagatcho and of course to cut the blade. I would suggest this one. I had a very good experience with this seller. He can tell you correct replacement part number. Also if you find his offers too expensive you can look for cheaper chinese alternatives.
http://www.ebay.com/usr/key_service
Edited by Arminator
has any one tried using
Vagtacho USB Version V 5.0 VAG Tacho For NEC MCU 24C32 or 24C64 to program the new key
I ordered one last week but when it arrived there was nothing on the CD I've tried searching for the software but everyone I've tried to download has been blocked as a "dangerous file" ???
well that is probably cheap chinese copy of a original tool which is waaaay more expensive... I`ve tried chinese copy of 3.01 Vagacho version and it didn`t work.
Edited by Arminator
