Belt change
Is it commonplace for a five year old Yeti with less than 25,000 miles on the clock to have a timing belt change.
You do not change the timing belt if you do not see any wear on the belt.
However if you have changed the water pump or any other pulley mechanism running thro' the belt , then it is recommended to change the timing belt to avoid another labour charge for doing the same.
Also ensure somebody experienced with Skoda repairs does the job . Not all mechanics can deal with a Skoda repair
Not strictly true.
There is a recommendation for 5 years for 2009+ cars or 120,000 (I think).
This may be different in India but for the European market that is the recommendation.
I wonder if stop/start has been factored into belt service life.
That is certainly NOT the advice given by Skoda!!
Or any manufacturer for that matter! They all have a fixed interval and not aware of any that say to inspect and only replace if it looks like it needs it.
From 2015 the petrol EA 211 family of engines [that covers 1.2tsi, 1.4tsi and a 1.6]  are claimed by VAG to have timing belts that will last the life of the engine. I have not researched the diesel engines. If you google it lots of info. available. Only time will tell if this is true.[Having spent a small fortune over the years on belt changes I hope it is true]
-And how often do you inspect your timing belt? :x
I have a feeling there will be another name added to my "Ignore" list!!
Timing belt that will last the life of the engine. Since when the belt fails the engine is pretty much dead its an acurate description.
I don't inspect my belt at all as long as you don't hear any unusual noise. In theory these belts will last for the life of the car . But practically it may not come true becos the component pulley that run through them fail and consequently damage the belt.
Ofcourse Skoda dealers will tell you to change becos it becomes there routine maintenance charge !!  60000 KM may be a number to inspect or replace but this by no way is accurate either.
I have never heard of any mechanical component being replaced unless it has a wear and tear.  Why would you replace something that is perfectly fine 'n running !!
Rubbish!!
And again!!
Its such an important belt that it falls into the catagory of preventative maintenance. As rubber and the fibers age they deteriorate through both wear, heat cycles, fatigue and just age. At a certain point the likelyhood of a failiure is high enough that its time to replace before it becomes a time bomb.
Edited by Parkesie
So basically we should wait till our timing belts and tensioners start making a funny noise? Then get the belt inspected and changed?
If it's making a funny noise then it's probably too late!
There's an old saying
Do it by the book!
(stoopid)
Do it by the book!
(stoopid)
There's also another old saying - If it ain't broke . . . . . . .
But this probably shouldn't apply in this case  :no:
Where is this ignore button?
Hover over the little arrow to the right of your name at the top right of the page, and go to Ignore Preferences. Instructions there.
Sometimes a little tolerance leads to further understanding of the world beyond the village
