Roomster blower not working (climatronic)
Hello just bought a 2007 1.9 tdi scout, very pleased with the car but a problem has just manifest.
The blower worked when I bought the car but has stopped working on any setting, it is the  climatronic version, read some forum info which is great on here by the way and get fault code 4f9 02 on the display.
as the weather here in South Yorks is so sunny and hot all the time thought id better get it fixed and was hoping someone could help or give me any advice or links as to how to repair or test which part is at fault.
Thankyou
Hi, I commend you on your splendid choice of car!
Not heard of this fault, but a google search using Fabia for Roomster gave a load of hits including the following video;
Good luck with it.
Edited by b1ackb1rd
I had a simillar problem until 2 days ago - the blower would work only on high speed or not at all.
The problem is with the blower which is broken but also, you will have to change the thermoresistence which is attached to the blower.
They are sold separately but I advise you to buy both. The blower is located behind the lower glovebox.
You will have to go to a good mechanic because you must remove the dashboard.
The lower glovebox is embedded in the dashboard  and there is no room to remove the blower unless you remove the dashboard.
They should cost both aprox 200 euro plus the work of installing the new blower.
Edited by Octavian_Nicolae
