car radio stream mp3
my radio showse only PHONE and dose not move ,what ever I press and I canot turn it off ...when I tried to put it in another car it asked me the code and done the same ....need help asp...
You'll need a radio code from a dealer.
Alternatively, there are plenty of eBay sellers who will provide a code in a few hours if you give them the serial number.
I have the code ,but it still wont work
Try reset the unit by disconnecting the car's battery and wait for 5 minutes.
Then try again.
stil dose not work ....any other options
Do you mean the code isn't accepted? If so it might be the wrong code or a broken headunit.
If the code is accepted and you end up on the phone screen, it is probably a broken headunit.
The code is correct, and stays in phone... New radio or fix it somehow
  • 1 year later...
@darkomaru : Did you manage to fix or figure out the problem with your Radio ? I have the exact issue now and it was working just fine yesterday.
Edited by msalahz
