VAG NOx update 170 DSG
I received my letter for an invitation to have the software update for the EA189 engines - 2.0L 170 BHP.
I am in 2 minds about the update....
Are there any people out here who had the update done to 2.0L 170, DSG, 4x4 and who DO NOT have any problems with it?
Does the update affect MPG and power output noticeably?
Does the update erase any coding done to the rest of the car?
I do not want advice on NOT to do the update. I am looking for positive responses.
you wont get many I doubt (positive responses)
Out of interest, why do you want to be talked into having it done?
There are a couple of threads that are moved to the General Car Chat section you might want to look at.
Then the Yeti section had questions on the 170ps, others in the threads in theOctavia, Rapid and Fabia sections covering 2.0TDI / 1.6TDI, not much on 1.2TDI's yet.
The only positive thing about getting the update done is knowing your car meets the EURO emissions standard it was supposed to in the first place.
The only independent, quantitative data I've seen on the update is positive. ADAC, OAMTC and TCS working with the Vienna University of Technology did back to back testing on 4 TDIs* before and after the update and found marginal impact on economy and performance.
* 3 Audi A4s and 1 VW Golf with 2.0 TDI and manual gearbox
ADAC later published data on a 1.2 and 1.6 TDI as well (I can't find a link to the 1.2 test right now).
http://www.skodaforhandlere.no/globalassets/20160627-oamtc_rk_27062016_en.pdf
http://www.audiforhandlere.no/globalassets/20160627-5288-tcs-testet-vw-software-updates_eng.pdf
https://www.adac.de/infotestrat/tests/eco-test/diesel_messung/default.aspx
https://www.adac.de/infotestrat/tests/eco-test/golf_16_messung/default.aspx?ComponentId=287165&SourcePageId=31832
The impact on economy and performance may indeed be marginal but it's the impact on the longevity of the EGR and DPF which concerns me.
My car will remain "unfixed"!
Drefaldwyn
If you look at the "trust" on the Skoda web site : note DPF not covered also fair ware and tear not covered. I would say they would have to advise if anything is not up to having update first
 quote
1. What is ŠKODA’s Trust Building Measure?
With the Trust Building Measure, ŠKODA is informing its customers that it would consider any complaints that are established to have arisen as a result of the implementation of the technical measure on vehicles with EA 189 type diesel engines and that relate to certain parts of the engine and exhaust treatment system. The Trust Building Measure applies for a period of 24 months from when the vehicle receives the technical measure and only to vehicles with mileage of under 160,000 miles at the time the Trust Building Measure is implemented (whichever comes earlier).
ŠKODA has always said that implementing the technical measure has no adverse impact on fuel consumption figures, CO2 emissions figures, engine output, torque, noise emissions, or durability of the engine and its components. All figures relevant to type approval for the vehicle will remain valid. The regulatory authorities have expressly confirmed that the regulatory requirements are met. The confirmation also applies to the durability requirements for emission control systems. The Trust Building Measures has no bearing on this position.
With the Trust Building Measure, ŠKODA is sending a clear signal that the update has no negative effects on vehicle durability. This measure should serve to strengthen customer confidence in the technical measure and should encourage more customers to have their cars updated.
Customers can soon receive detailed information about the terms and scope of the Trust Building Measure from all authorized dealers and workshops for their respective vehicle brand.
2. Which brands are offering the Trust Building Measure and which models are affected?
The Trust Building Measure applies to all Volkswagen, Volkswagen Commercial Vehicles, Audi, SEAT and ŠKODA models with EA 189 type diesel engines that have received the technical measure.
3. To whom does the Trust Building Measure apply?
The Trust Building Measure will be offered to all ŠKODA customers whose vehicles are fitted with an EA 189 type diesel engine and who are having their vehicle updated as part of service measure 23R6 in the context of the diesel matter. It applies only to vehicles with mileage of under 160,000 miles at the time the Trust Building Measure is implemented. To be eligible, customers must present proof that all manufacturer-recommended service and maintenance work has been completed (i.e. this applies to vehicles with a full service history).
The Trust Building Measure also extends to all customers whose eligible vehicles have already received the technical measure, from the date they received it (provided that all other requirements for the Trust Building Measure are met). The Trust Building Measure is linked to the vehicle identification number and would extend to a new owner if the vehicle is sold within the 24-month period covered by the application criteria.
The Trust Building Measure applies worldwide with the exception of the United States, Canada and South Korea, which are subject to different regulations.
4. Which components are covered by the Trust Building Measure?
The Trust Building Measure covers a total of 11 components within the exhaust gas recirculation system, the fuel injection system and the emissions after treatment system: lambda probe, temperature sensor, EGR changeover valve, exhaust gas recirculation valve, exhaust gas recirculation pressure differential sensor, injector, high pressure pump, fuel rail, pressure control valve, pressure sensor, high pressure pipelines.
The Trust Building Measure has no bearing on ŠKODA’s position that the technical measures do not have any negative effects on the durability of the engine and its components. The regulators have confirmed that the technical measures meet all legal requirements and have no adverse impact on fuel consumption figures, CO2 emissions figures, engine output, torque and noise emissions.
5. What are the conditions for the Trust Building Measure?
In addition to the conditions outlined above:
(1) The Trust Building Measure
  • can only be made to, assessed by and used with an authorised dealer,
  • applies to complaints only in materials used and work performed on the following components of the EGR, fuel injection system and emissions after treatment system: lambda probe, temperature sensor, EGR changeover valve, EGR valve, EGR pressure differential sensor, injector, high pressure pump, fuel rail, pressure control valve, pressure sensor, high pressure pipelines,
  • does not cover replacement vehicles, out of pocket expenses, damages etc.
(2) provided that
  • the affected EA 189 vehicle has participated in the service action 23R6
  • the vehicle has been correctly serviced in accordance with the service schedules, updates and recalls as required by ŠKODA
(3) and provided that none of the following cases apply:
  • cases of natural wearing, ie impairment of vehicle by wear and tear,
  • the owner or a non authorised service partner or dealer has not orderly repaired, serviced or cared the vehicle (e.g. by using non genuine parts etc.),
  • instructions for operation, treatment and care of the vehicle as e.g. outlined in the instruction manual have not been met,
  • vehicle has been damaged by third party instances or external conditions such as accident, thunderstorm / hail, flood etc. which has caused the issue complained of,
  • any complaint regarding the particulate filter which is due to ash load,
  • parts have been built into the vehicle or the vehicle has been changed in an unauthorised way, e.g. through (chip) tuning,
  • vehicle has been operated improperly, eg for motorsport competitions or in case of overload,
  • vehicle holder has not notified a complaint within a reasonable time frame,
  • vehicle holder has not given ŠKODA the opportunity to deal with the issue within a reasonable time frame.
The car always met the EURO standards, all the update does on the 170 is remove the "cheat" software.
It didn't meet the standards all the time which was the problem.
The cheat mode set the car up to run in an emissions compliant mode under certain operating conditions (basically when it figured out it was on the NEDC drive cycle). Outside of test conditions it ran in a different mode which was not compliant with the emissions regulations it was obliged to meet, hence the problem.
The update is a substantial change to the ECU's operating software to make it compliant with emissions regulations under all operating conditions.
Why would they need to update if the car met the standard (outside of testing environments)? What's the issue then?
Received, probably the same, letter few days ago - as long as not having update done won't cause MOT failure - won't gonna happen to my car - ever.
Unless they pay for dyno before and after :)
I've had the letter this week. It's gone in the bin. I'm not willing to take the risk as car drives nicely as it is.
The letter with the DVSA markings made it look more official than it actually is.
Thanks for posting that link chimaera - I have been looking for some before and after power, torque and consumption graphs for the 1.6 diesel with the hardware/flow straightener + software update solution. The ADAC summaries were interesting - especially as the values applied over almost the entire speed range:
"after the update 6 kW more maximum performance than before."  (i.e. 105 to 113hp)
"torque curve increases after the update and shows an overall higher level; Up to 10 Nm more are available"  (i.e. 250 ft lb to 257.5 ft lb)
So, if I get the emissions fix applied at the next service in August - do you think I should report this performance remap to my insurer...?  ;)
There won't be any 'positive' responses.
It'll either be...
"I've not noticed any difference"
Or...
"They've ruined my car, help!"
So why bother? If your contribution to pollution reduction is important to you then go for it. If driveability and long term reliability is more important then don't risk it.
While we're talking silly propositions, would you get more gains from a remap with the flow straightener? :D
On a 2 litre diesel - you already had the flow straightener built into the MAF.
On my 1.6, the hardware portion of the "fix" could be summarised as simply putting in a feature that should have been there in the first place (at least, it "should" have been there in order to properly meet emissions requirements).
Unlike petrols that use the MAF for fuel calculations, I read that the MAF's primary purpose in a diesel is to provide information to calculate the EGR flow rates.  The flow rates need to be managed/increased by VAG for NOx reduction.
However, as the article below points out, "Increased EGR flow can cause increases in soot build up along with the need for increased maintenance on an engine. It can also cause premature failures on some engine components"
The Truth about Cars - How the VW Flow Straightener Really Works
MAFsensors.jpg?w=2000
