Electric Problem
Hello to everyone,
I just bought a skoda octavia a5 from 2006 1.9tdi with a dsg6 gearbox, but two days after I bought the car it just stop and the lights in the dashboard went crazy, starting with the steering wheel going yellow and them red and all the other lights air bag check engine oil level and the rpms and temperature needles went crazy too, I just change the alternator and check the negative wires that make contact with the chassis and even change the relay 100 that goes on the engine bay but the problema still persist... please can someone help me this, thanks ur time
Edited by Guillo
Have you fitted a new battery?
Yes, I just bought a Bosch s4 and change the alternator regulator also and earth wires and the relay 100 but still the dash board lights come on, I've notice that usually happens after an hour of driving is like something gets to hot and them happens... I took it to the skoda dealer and they run the vag com program and they say that all the warnings are not true so they erase them all... but happens again
What about trying to focus  on the engine ecu?
All these may be caused due to faulty pcb's...
Hello there... thanks for ur time actually it's fixed... the problem was two wires that were making contact... this wires were from the body control module so that was why everything start failing... but took me a month to discover cuz only did happen when the day was pretty hot, at noon...
Thank u anyways
Ok -glad all ok after hassling..! :thumbup:
