My vrs wont start coil and immo key light flashing it was fine this morning anyone help please
Sounds like your reader coil is suffering connection issues, remove the instrument cluster and reflow the PCB connector.
Reflow ??
Have you got a spare key to try?
I havent only got one key
25 minutes ago, Vrsjimbobmk1 said:
Reflow ??
The solder joints marked in red circles in the following pic are the immobiliser connections. The joints can become bad and need reflowing with a soldering iron - i.e. remelting the solder to make a good joint.
Just bought a remapped ecu kit off a mate
That was dumb, the alien ECU will not work in your car without recoding.
Its a full kit it plug and play isnt it
What do you mean by a 'full kit'?
Ecu clocks key barrel and transponder
