Better Engine Mounts
Has anyone fitted better engine mounts on their tdi? My ones have failed at 60k and i think fitting factory ones won't last long.
cheers
Do you refer to bushes? I think power flex do poybushes but some types are not recommended for the TDI engines. Be sure you fit a recommended item. I think it may be due to vibration.
If in doubt get the factory ones fitted again, they may fail but at least they are the right ones for the engine.
nope, i mean the actual engine mounts. Left right bottom.
vibra technics do uprated engine mounts but they are not cheap
Just be aware if you fit uprated / stiffer engine mounts you will be potentially introducing a lot of vibration into the cabin.
