Start&Stop reverse function?
Is it possible to somehow change the function of start&stop key? So it would either remember last state, or have a reverse function?
I know that this is possible on audis, but I haven't found the solution for skoda suberb anywhere.
But more explanation on your query please?
@Insect_repellent:) if you are talking about Start&Stop button - and you want it to be always OFF - then there was some info about using VCDS to code minimum temperature and set it very high.
does turning ot off using voltage render the button obsolete?, i would like to retain the function but have the starting setting as off. is this possible?
Edited by JohnnyType2
Yes, I was talking about the button, sorry:) No, I don't wan't it to be always off. I just want it to be off when I start the car and to have the possibility to manually turn it on.
it would seem there must be a start setting, it will be either on/off so you should be able to change it. no one has found this yet AFAIK
I think most (or the good) chiptuners can do this. Here in NL it's usually free if you do a custom chip tune.
Ask them what the settings are? At the moment we can only permanently turn it off with a voltage mod. Not ideal. I know there's an Audi vcds mod that can change it the correct way.
