VW Caddy mk2 (Felicia) Pick-Up 1.8T
@D.FYLAKTOS This is all of the info on the front brakes which I found in TeflonTom's Felicia 1.8T transplant thread.
https://www.briskoda.net/forums/topic/209180-felicia-18t-transplant-thread/page/4/#findComment-2991830
https://www.briskoda.net/forums/topic/209180-felicia-18t-transplant-thread/page/4/#findComment-2991838
This is essentially the same as what I have told you already. The 'little spacer' which is mentioned as being required between the mounting lugs and the caliper carrier bracket is actually some chunky washers with a total thickness about 5mm. I had in mind that the holes in the mounting lugs had to be re-tapped for larger bolts, but I can find nothing about that in this thread so I am not sure now.
Next time I have a front wheel off my Caddy I will check the size of the caliper mounting bolts and confirm on here. I discovered that I have a 14" wheel here too, so I will try that and see if the Mondeo calipers fit under it. It is actually a Vauxhall steel wheel so it will not tell you definitively whether your 14" wheels will fit, but it should show conclusively if they will not.
Edited by Bete Noir
  • Replies 125
  • Views 56.9k
  • After the prang I had in April, the front end had been looking very sorry for itself. My preferred bodyshop managed to fit it in to get it looking more Caddy-shaped and get me back on the road, but it
  • Real progress   Once back together, it was treated to a liberal coating of stonechip
  • All the transplant bits which Tom had fitted to the Felicia with a combination of inspiration and perspiration were swapped onto the Caddy without requiring much of either (especially from me). The re
