Buying a high mileage DSG 170bhp
New flywheel 50,000 miles ago and fluid 10,000 miles ago.
Go see a VW Specialist or Automatic / DSG specialist and do not mess about with trial and error. IMO.
  • Replies 51
  • Views 17.8k
  • Scottandbobbie
    Scottandbobbie
    Hello people of Briskoda, thought I would post a photo of the Superb, it’s completed it’s first week of commuting, averaging 44.3mpg (actual).   The DSG in-line thermostat (or coolant regula
  • Simply because Ben’s service went above and beyond what I expected on my 1st car I took there (170CR Superb) the following two were done on their special offers, the money saved paid for my fuel to go
  • Being a 2010 model, has it had the software 'fix' applied, if so it could be a lot of expensive trouble. You can check the car if you have the VIN at http://www.skoda.co.uk/owners/dieselinfo/check-you
Hi guys, so update on the dsg issue and abs issue. The rear left abs sensor had been split in two by rust flakes from the abs tone ring. Changed the sensor and replaced the bearing (as the ring comes as one with the bearing) all is well now with the dsg, changing as it should.
new problem, a/c has stopped working.
does Skoda use a clutchless system or a clutched system. Vcds shows no errors, looked at the compressor, the belt pulley is turning but the centre section isn’t. There’s no noise, checked fuses all good.
Anybody had had any issues with their a/c? Any help would be useful.
regards Scottandbobbie
