What is the oil capacity of 2007 Octavia 1.6 FSI?
Hi all,
I have been Googling for the past half hour with out a definite answer.
Can someone confirm what the oil capacity is on a 2007 1.6 FSI Octavia?
Many thanks
Yeah, that was the only source I could find but am not sure I can trust it.
I would quite like to find a second source!
Doesn't it say in your owner's manual, in the technical data section? I'd just buy a 4 litre can and go from there, there is an allowable oil range so you're unlikely to under fill if you get at least 4 litres, if it isn't full after that then go get a smaller can and top up saving the remainder in the boot for later topping up.
Hi all,
I just found the technical data booklet and can confirm that both variants of the 1.6 have 4.5L listed as the oil capacity.
This should be with new oil filter replacement.
Would you ever change the oil without changing the filter at the same time?
I did in some older cars when changing in every 5000..
Not turbo engines of course...
Many would not like this.
