Clutch help
I've a 2000 fabia 1.9sdi estate
With high clutch , what clutch do I need
Is it slipping or having trouble changing gear? If so maybe a bleed of the fluid or change of cylinder .
If not then just learn to adapt to it.. A high clutch doesn't always mean a problem
Its just high , don't slip hardly just now and again under hard acceleration.
Sometimes a slight judder in long traffic stop starts.
How do you bleed the system thought my old type was cable.
  • Sponsor
All Fabias have hydraulic clutches as far as I know, the gear change is cable.
The system can be bled somewhere around the gearbox. As far as I've read it's a plastic bleeder valve which is very likely to snap, so I would avoid unless necessary. I'm sure more of an expert can expand on this
