Yeti 1.8TSi brand new engine - a success story!!!!
23 minutes ago, Yetski said:
 I purchased my Yeti from Marlborough Cars, Isleworth back in 2013
Do I have any consumer rights whatsoever?
Not with regard to your purchase in 2013. The maximum six months has elapsed long ago.
  • Replies 59
  • Views 15.3k
  • aka_pseudonym
    aka_pseudonym
    I don't know but Furrows thought it was brand new.  This is the block marking.  I was told that the number one down from the top (140218) is the actual manufacturing date.  They'd had reconditioned en
  • Brand New from the Factory can be a Refinished engine straight from the Factory, so the Block that was returned from previous use is stripped and then used without having been melted and recast.
  • aka_pseudonym
    aka_pseudonym
    And Furrows also pointed out that it had a lot more ready fitted than they'd expect on a normal "base" engine.  Even has the oil filter on it!
29 minutes ago, Yetski said:
Car is 2011 1.8 TSi
I’m aware of the issue but wanted to know if anyone has had this lately
ive got the dreaded piston oil leak issue (I think)
2 litres of oil every 400miles
tailpipe is really sooty
been ignoring for a while but can’t anymore
Looking at getting not getting issue diagnosed for ££££ and just getting a recon'd engine and paying £3.5 -4k for whole job
Before I do this ...
Many thanks
I would doubt it, sorry.  Way too much time has passed I think.  But there's a lot along the lines of "goods fit for purpose" in the Consumer Rights Act so I'd suggest a call to the RAC legal services just to check.  It's a free service and you didn't have to be a member when I used them.
Also beware - the chain tensioner needs oil pressure to function.  If the chain starts jumping links the pistons will eventually hit the valves and that'll be it.  That's what happened to mine.  The repair "kit" includes latest spec pistons, rings, conrods, chain and tensioner and might be a cheaper alternative to a reconditioned engine.
Good luck.
And so all is not totally depressing - have you noticed that second hand prices for petrol 4x4 Yeti's are going UP?  I reckon mine is possibly worth £2k+ more now than I paid for it three and a half years ago.
Good luck.
Many thanks for replying will all that info. Are you saying there is more to consider than just paying £1600 odd for a recon'd engine online (247spares) ?
The car drives as smooth as it did when I first got it, all thats gone wrong with it was a clutch release bearing a few years back (£800) and the odd coil pack replacement - it still drives superb and pulls like a train :)
As the purchase was made in 2013 I guess the Consumer Rights Act (2015) won't apply, it would instead have fallen under the previous Sale of Goods Act - which wasn't as much help for the consumer?
Well this is just my personal way of looking at it - I'm sure others might well disagree!  Obviously with mine I was within the one month/six month window and Skoda eventually capitulated and it got a new engine, but I had a lot of time thinking about alternatives while they were all arguing about who should or shouldn't pay.
1) You'll have no idea whether the "reconditioned" engine is going to last.  But if you get yours reconditioned you'll know what has been replaced with what, and therefore you'll have faith it'll last.  I think "reconditioning" for some suppliers just means cleaning off the thing with a bit of gunk and checking cylinder pressures etc.  It won't necessarily mean it'll be fitted with the revised parts which by all accounts are good.  VW had so many of these engines fail - mainly because of the piston/rings design - that they did a good job of rectifying the early faults.
2) The engines are very common - fitted in VW's, Audi's, Skodas and Seats.  They aren't some black-arts supercharged specialist unit with counter-rotating balancing shafts etc!  It doesn't need a Skoda dealer to sort it out - that would really only apply if it were being done under warranty.  There are far better independent mechanics about anyway!  I have a garage 50 miles from me (mid Wales) who used to be an approved Subaru Service place - the mechanics there have probably forgotten more than a lot of Skoda Dealer mechanics have ever learnt.  I would have given mine to them for a rebuild which they probably could have completed in a week (in between sorting rally cars).
3)  The engine could probably be rebuilt in situ although some mechanics would possibly prefer to remove it from the car.  It would only be a matter of head off and sump off to change the pistons and con-rods.  I think the timing gear is accessible from under the bonnet.
4) I don't know how much the parts would come to - I'd guess around £500-£750.  That particular garage I've mentioned charges £65 per hour, the nearest Skoda dealer to me charges £135 per hour.  So all things considered the final bill might not be far off the cost of a "reconditioned" engine unfitted.  But the big plus side would be that you'd know what had been done to your engine, know the work was good.
5) My brother once had an Alfa 145 Cloverleaf and blew up the engine.  He bought a reconditioned one to replace it which was well down on power from the start and also blew up 6 months later.  So I'm a bit biased where reconditioned engines are concerned.
6) Any independent garage that says it "specialises" in VW's or Audi's should be able to give you a quote for a rebuild over the phone because these 1.8TSi engine problems are so common.  I'd certainly get a quote or two to compare with the £1,600 for a reconditioned unit.
7)  I wouldn't procrastinate for too long!
Just my way of looking at it obviously, but I hope that helps..
Thank you for such a detailed reply, really appreciate - Im half in mind now to sell it with the problem - webuyanycar quoted me just over 4250 with the issue (its done 60k) so may just take them up on that
Fair enough.  As I said before they seem to be selling for a lot now on Autotrader - possibly £7,500 or more for yours - so that'd be room for them to sell it on to someone who will do the engine rebuild and then still make a profit afterwards.  In my situation four wheel drive is an absolute must and the petrol Yeti is about the only option available which is a proper 4x4 as opposed to a glorified chelsea tractor or something the size of a tank.  Good luck whatever you do.
Having said I have just emailed a load of VAG specialists in my area (this lot look promising http://www.audivwspecialistleatherhead.co.uk/info2.cfm?info_id=198615) so will wait and see - my goal is to keep it as like you say (despite its grandad looks imo) its one heck of a versatile car :)
Edited by Yetski
I like the oily hands in the picture on your link - proper mechanic definitely!
You say "despite its grandad looks" but look what's being produced now - I'm not so sure that that shouldn't be "despite its long before its time" looks.  What do these remind you of:
2022 Land Rover Discovery:
2020 Kia something-or-other:
Both uglier of course but you'll get my point.
Agreed, they are horrendous looking but I guess thats electric cars in general
It's a stock photo from Google, not any specific mechanic I'm afraid.
Edited by Rustynuts
Ah, good spot!  The socket wrench did make me wonder, certainly not Snap-On.  I actually have one like it in 3/8" and it has lasted for decades but it's irritating - you have to give a quarter turn to the plastic centre on the top to change from undo to do-up or vice-versa - but it's a clockwise turn to change to undo (anti-clockwise) and an anti-clockwise turn to change to do-up (clockwise).  Unintuitive to put it mildly.  I've often wished it'd bust so I could throw it away but it never has.
On 24/07/2021 at 15:52, aka_pseudonym said:
The factory 1.8 TSI  repair "kit" includes latest spec pistons, rings, conrods, chain and tensioner.
What are the VAG part # for this repair kit ?
Error
Edited by aka_pseudonym
Sorry, I wasn't clear.  It isn't a single part number.  It's the list of parts to be replaced when a factory approved repair is carried out.
  • 6 months later...
Bump for the new member from Australia.
OK, but do you have a list of what parts and what part #'s that are involved ?
No, sorry, I don't.
Update: Not a lot as happened as been busy with work but the time has now come to get this all sorted once and for all - compounded by the fact that Autoglass replaced the windscreen for a chip last summer and the rear view mirror was found to be hanging by its cables yesterday morning 🥵
 So as well starting to get new engine rebuilding quotes I now have find someone who can reconnect the rear view mirror
Ive disconnected the mirror from the loom but wondering who could stick it back on??
IMG_2567.thumb.jpeg.847b42a7f8b52dd8e1216b63827772e3.jpegIMG_2566.thumb.jpeg.5fc51a2610d88d05e86013f5465ca3ca.jpeg
Back to the Engine Issues
In Summary - 1.8 TSi 4x4 2010 (118kW)
Engine Number CDA 18****
Oil is 5w-40 Synthentic
Oil Consumed is 2 litres every 400miles
If asking for a quote on an engine rebuild what exactly am I asking for? Rings/Conrods/Pistons? New Chain?
What am I looking these days? £2.5 - 3k?
This is the current state with the cover off - looks like there's lots of oil leakage?
Edited by Yetski
Indeed it looks like a lot of oil leaking.  Where from when cleaned up?
That is not what the issue usually is with Euro 5 1.8 or 2.0 TSI,s,  They can use oil and no mess.
Possible Head gask?
Engine:   ( 2010 ) 1.8 TSi ( 118 kW )
Engine code:   CDA
Engine Oil:   5w-40   Fully Synthentic.
Oil consumption:  2 litres every 400 miles.
If asking for a quote on an engine rebuild what exactly am I asking for ?
Rings / Conrods / Pistons / New Chain / etc.  ?
Actually 2 completely different and independent problems.
* 1. Problems are with the factory fitted pistons piston ring groove design and piston ring design ( poor and wrong design ).
       ----> Solution. Install completely new pistons with a different design of both piston ring grooves and piston rings.
     No problems with the conrods.
* 2. Fit a new timing chain with all associated wear parts.
Thanks, would the mechanic need some of blueprint/part numbers to make the required changes etc rather than just replacing what’s already there with the same parts?
Edited by Yetski
I'm sure the original, badly designed parts would be unavailable.  The VAG parts list would say "superceded by ....."
The chain tensioner uses oil pressure to work.  That's why the chain runs slack when the piston ring slots line up - as 2stroke said it's very poor design.  Once the oil pressure gets too low there's a chance the chain can jump its sprockets and then armagheddon follows.  The design of the chain tensioner was changed at the same time as the pistons so that should be replaced along with the chain too.
