Trevorb33’s Fantasygreen Fabia 1.8t build take 2
Last bits of suspension done, eibach 22mm farb, hopefully get it booked in for alignment again next week.
Also my samco intake hose arrived after two months of waiting for it to be made so fitted that
  • Replies 236
  • Views 33.3k
  • New Cars here
  • Couple of hundred miles in now  did a scrap run this morning too so had her on a weight bridge 1220kg with 1/2tank fuel
  • Finally wired in the speedo, was actually quite straight forward as I’d already had the PIN number and connector I needed to wire it into, used a octy mk1 vrs speedo drive Cheers Ross for that info in
Have you noticed any difference with the thicker front ARB Trevor? I’ve got one mine but not driven it yet to see😂
Same not driven it yet haha, hopefully get out in it end of next week.
just been for a good run, initial turn in seems a lot sharper with the new arb, and small adjustments in steering seem to react very quickly, very impressed. Probably be even more noticeable with your slightly heavier diesel lump.
Getting it aligned again next week as I’ve had the subframe off so should be even better :)
That's a positive review, cheers for the update fella.
Wheel alignment sorted today from Motorsport and performance other side of leeds, camber was all good and nicely even so no need to touch subframe again which was nice. Toe was well out again, now adjusted and driving lovely and straight again :) .
turns in even better now
  • 3 months later...
Edited by TrevorB33
I’ve had her up for sale half heartedly, only advertised on here and abit on instagram. I think in the back of my mind I don’t want it to go.
ive just been in the middle of a house move so now the decorating and boring stuff has been done I can pay the Fabia some attention.
I’ve been meaning to do the cambelt as it’s reached it’s age limit although only done 30k since it was changed.
lucky I did as the littler roller idler bearing had half failed and was moving in and out rubbing on the metal casing cover, and the plastic impeller water pump had started to break up too. Luckily caught them both before it was too late.
so new Ina kit fitted and a metal impeller water pump
Managed to pick up a bargain genuine seat sport front mount off a 1.8t too so correct pipework, very hard to find, I’ve already cleaned it out and going to wire wheel end tanks and paint it black this week then get it on.
Also fitted some poly exhaust downpipe mounts,
And I’ve changed the gearbox oil :)
and booked in for getting the roof resprayed so she will be looking mint
Edited by TrevorB33
Intercooler all cleaned and sprayed and looking great, ready to go on anytime now, been out for a nice drive too
Glad to see its still going Trev!
Now sold!! End of an era
Guest
