Passenger headlight no power! HELP
Yes you explained it fine.
I will be about at times tomorrow and will check here when I can.
  • Replies 55
  • Views 10.5k
  • Jackturno1
    Jackturno1
    Thank you if you search on Facebook modified lights UK he make some mint lights these are custom built from him:)
  • Both dip/main not working would usually suggest an earth problem but if you say there is nothing at the other wires it can't be.
  • Ah that is run by a briskoda member called @hutchysrs50  Good guy!
Great, thanks
The dip and main go through a bulkhead disconnect a 12 pin white connector Dip pin 1 Main pin 3 (pass headlight) & Dip pin 2 Main pin 4 (drivers headlight)
Thank you we’re is the 12 pin connector?
Edited by TMB
I like your DRLs by the way!
it just says "multi-pin connector at the front wall"
there is only two white connectors on it and the other one has 11 pins
I did tried to find these earlier today and can’t find them, I thought if the fuse hasn’t gone then follow the wires back to this but couldn’t get to it
Ok it says there are two variants but both require the wiper motor to be removed to access them
I’m confused we’re does it say this do you have the haynes book? I don’t have the wipers on mine, are the connectors in the dash somewhere?
He means the windscreen wiper motor because the connector will be at the bulkhead.
This is from Elsawin basically a copy of the dealer manuals
Unreal build quality such good lights just yet to get to see them fully working
Okay don’t know if I’m being stupid but would that be under the scuttle panel?
Bulkhead connectors look like this (pics courtesy of Wino)...
20180714-180051-thumb-jpg-1e3028ecec8198
20180714-182427-thumb-jpg-462593bfbf20c2
20180714-182532-thumb-jpg-8af62343b0d334
20180714-182539-thumb-jpg-119b2e60f9884a
Edited by TMB
Yeah that second from last picture shows the connector bottom left
Edited by nige8021
new picture added
Right! Now we’re talking I couldn’t work out where anyone was meaning, I’ll be checking in here tomorrow, so fingers crossed there will be a blown wire in here or something along those lines
Yes you were right - it's all under the scuttle panel.
I would leave the bulkhead until you tried everything else first.
Thnsk to both of you for your help I’ll be trying the wire trick first then if that doesn’t work I’ll probably be working on the bulkhead box then
^ :thumbup:
11 hours ago, TMB said:
^ :thumbup:
Hi mate just tested the wire from the fuse to the plug and it gave power to the light what is the next steps?
If it was me I'd just run a new wire to bypass the break. Otherwise you are going to have to find exactly where the break is.
You could do the same wire test for the main beam from fuse 30 but the main beam bulb is different (H3) and only has a single spade connection.
Edited by TMB
Where exactly would I run the new wires from?
