No ROD file found
I tried to use the lastest VCDS version and use Cent. Elect, but when I try coding and saving afterwards , It doesn't save and give me the message "Unable to find a .ROD file for: EV_BodyContrModlu1UDSBosc 012003 (VW37)" , any fix for this problem ? Should I wait for the next updated version for this ROD file
Log-WVWZZZAUZEP569616-159762km-99271mi.txt
Send the Log off to Ross-Tech
Quite possibly one they haven’t seen as yet so as above, send them the file.
Did you also update the firmware as well?
What cable type do you have? The scan shows modules that are incompatible with the cable you have, so maybe you should consider upgrading to a HEX-V2 or HEX-NET?
  • 4 weeks later...
The OP is using a knock-off.  They are known to give poor results.  No need to send anything to Ross-Tech unless it comes from a legit system.
