I need Bolero Update :-)
Hi!
I need update for my Swing.
Thanks in advance
  • Replies 1.2k
  • Views 216.6k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
1 hour ago, Gx3m said:
Hi!
Thanks in advance
Update sent
9 hours ago, varooom said:
Update sent
2016 Skoda Fabia 3
Although I have updated the car multimedia, when I connect my phone with an apple cable, the call sound stops after 2 minutes while making a phone call.
I have to unplug the cable and speak over the speaker. what is the solution for this error?
4 hours ago, iirfansk25 said:
2016 Skoda Fabia 3
I have no idea, I have never used Apple phone
3 minutes ago, varooom said:
Apple telefon hiç kullanmadım bilmiyorum
Do you have a newer version than 0369? maybe even 4xxx. I'm ready to disrupt the multimedia.
Yes, but that can break things, not worth doing IMHO.
Just now, varooom said:
Evet, ama bu bir şeyleri bozabilir, IMHO yapmaya değmez.
If possible, send me the link and I'll try it.
Witam szukam aktualizacji do radia jak na foto. Będę bardzo wdzięczny. Skodę Rapid20221002_182433.thumb.jpg.1402ab81d1f1ff7b7743c228d6ed4fdd.jpg
Please post in English as per the forum guidelines. You’ll likely get more help this way too 👍
Hello everyone,
I am searching this firmware MST2_EU_SE_ZR_P0516T  for my seat, the only one that I found is on the website mibsolution.one but the download is so slow !
Do you have any idea where I can find this update ?
Best regards
2 minutes ago, leonidas_mk3 said:
Hello everyone,
Best regards
Install Free Download Manager and intergrate this into your browser.
It will then capture download link and speed it up.
Try speed and report back, otherwise I can supply if needed.
Unfortunately the speed download is too slow, even with the download manager.
But thank you for providing a solution
I will unpack/pack you then my file.
Probably 20 minutes of work.
14 hours ago, Krzysqu said:
Press and hold down your Menu or Setup button for 10 seconds, to then enter the hidden engineering menu, and then please take picture of your Software Train.
I suspect I know the value, but I would rather see to be sure.
Edited by varooom
10 godzin temu varooom powiedział:
Naciśnij i naciśnij przycisk Menu lub Setup przez 10 sekund, aby wejść do ukrytego menu inżynieryjnego, a następnie dodaj zdjęcie swojego Software Train.
Podejrzewam, że znam wartość, ale słuchałbym się.
Hi. Thank you very much for your support. I already have the software number. Your instructions helped me a lot. Thank you again😀..
I will send you new version, but I mention the page here as it contains the real firmware update button.
I have a Bolero in my Yeti 1.2 Tsi SE.
It works ok. I don't have Smart Link enabled.
Is it worth me updating?
Yes an No,
Update might make it boot faster, more stability, maybe you might get a better sound profile who know.
If you system is working, and you are happy, then you could just leave it alone.
Yes an No,
Thanks Varooom,
I am a beleiver in the notion, " if it works leave the dammn thing alone.
But I sometimes choose to ignore my own thinking.
Could you give me the file update.
I don't have a Skoda SD but have others I can re-format to fat 32, would this be OK?
9 minutes ago, cado said:
Thanks Varooom,
Well, how about you sleep on it!
When you get chance, press and hold the Menu button for about 10 seconds, then look around for something to do with Software Train.
And you can update firmware using any SD Card, only maps need be a Skoda sanctioned (CID Card ID)
Meanwhile I will sleep on it, so you have no rush.
Wondering if my vehicle has a software update available
Skoda Fabia Mk3
Device part number: 5q0035820
Hardware: H11
Software: 0138
Media Codec: 1003.113.1.15 prod
SW train: MST2_EU_SK_ZR_PO138T
SW MU version: 0138
software version: h21.50.93_STD2_EU
I would be grateful for any software update available for my system - many thanks.
Skoda Fabia Mk3
Hardware: H11
Software: 0138
SW MU version: 0138
0138 is the current version for the 01xx SW Train
I will send you 0138 version
Hello
I think there’s an update available for my swing that reportedly deals with the apple play crackling issue?
20 minutes ago, stoo31 said:
Hello
Yes to 8755, this cures the crackling noises.
