DSG Box or Engine/Electrical issue??
Definitely confirmed it's a coolant leak had a butchers with a mate removed slam panel from front which was full of nice pink coolant, from looking would appear to be the rad as its was running right along the bottom of it while engine running warm 😬😩
  • Replies 51
  • Views 5.9k
  • @ArranMac1 On a good surface with nothing about. Hold in the TC (Traction Control button)  & put TC off, and in D boot the car from a standing start and see if you have the same thi
  • Baring in mind that’s dealer prices, I done mine for under £150 and 2 hours of swearing.😄
  • Get it plugged in would be my first go to, I have 2 OBD readers and thought my car was error free then plugged it into VCDS two weeks ago and it threw up ignition timing faults. If you can, Unplug the
The saga continues with my random running issue has taken a new turn error wise only have one code come up since new plugs & fuel filter fitted which is Fuel rail pressure low, been told could be fuel pump, fuel sensor, in tank filter blocked, small hole or blockage in fuel line from the tank & a mate has mentioned a vacuum line that runs to the fuel regulator?? Any new ideas much appreciated 😁
