TV Tuner in Superb Mk3 Retrofit?
Tv tuner is power and MOST only.  In 5F  there is an adaptation in Car_Function_List_BAP_Gen2  > TV_tuner_0x2C_msg_bus , Comfort data bus is selected i don´t know if it is the correct one and have lots to choose.
  • Replies 85
  • Views 26k
  • Funnily enough last time I had to wait in the car I watched Sky on the iPad with the case flipped over the steering wheel to hold it up. The TV Tuner doesn’t do on-demand 😂 I was at the vets, our
  • Could have cropped the image a little mate😮🥺
  • Alternative   Hi Guys.. Bit of a curveball but here's a potential solution (It certainly works for me!)   Requirements. Carplay enabled MIB Jailbroken iPhone.
There’s a single LIN wire to the 5F, has this been added?
you’re right about no canbus
Hello, yes the ring break diagnostics cable was plugged to the 5F. Here is the scan with odis.
Edited by Camarao69
So much back and forward all this time and every thing was working  , you don't have to enable 57 tv tuner in gateway because it talks to the mib2 unit 5F (5F is a Most bus master ) and obdeleven did not help in here because it does not scan most bus modules . A year after and i have it working finally.
Edited by Camarao69
Thank you for sharing! I'm keen to enable this for my Superb!
Roy - Singapore
Hello , i as able to see tv in the back monitors but if i want to pass multimedia from the mib unit i can´t , how ca in achieve this ?
What are you using for the rear monitors as i assume they are aftermarket? Didnt think the superb came with them as standard?
Yes they are aftermarket , but the tv tuner just conects to te monitors through rca cables yelow red and white . I always thought that they would mirror the mib unit but now i'm starting to think that it works just like this . The tv tuner it self does not have many configurations to switch via odis.
/cdn-cgi/mirage/250e36b55f1bb7d3351388ef5c6893f6613c4f5336e7f158a718e2e3d2398eea/1280/https://www.briskoda.net/forums/uploads/monthly_2022_12/20221227_154437.thumb.jpg.1e017c1b7f5df0fb362a612e5c0b21e2.jpg
I have been contacting obd 11 because of  most bus modules not showig  , they have now updated the aplication and it is working.1885133327_Screenshot_20230121-142642_OBDelevenVAG.thumb.jpg.ae184abe1954a3c0eb3ee8ba245fbb2f.jpg
  • 4 months later...
Does anyone know if the dvb tv tuner was carried over to the larger columbus 9.2" screen that is fitted in the facelift superb models 2019 and above?
  • 11 months later...
It was never fitted as standard. But yes it works with it no problem. (MIB2.5, NOT MIB3)
