New FL Skoda Superb 2020 tail lights - retrofit?
You need to join the signal wires from all four of the rear light modules (according to the diagrams here) into a single one and lead that one to BCM.
  • Replies 239
  • Views 83.7k
  • Go and buy a FL and stop imitate it... (facepalm)
  • thread update.   thanks to Mo, we've got part numbers for the Sedan. unfortunately there is only one supplier identified thus far, and its too bloody expensive - https://www.skodaautote
  • silver1011
    silver1011
    I disagree, I think the new rear lights freshen the car up quite nicely...
@Istarish thank you! So basically i need to bring only single wire to boot area from BCM and split it there.
I personally did the splitting beneath the C pillar interior trims.
Only one cable goes from the BCM to the rear and is then slid to all four lights
Thanks guys 👍 I routed the cable yesterday
Is it works? What BCM do you have?
I did rear kessy retrofit, so I just prepared the cabling for rear lights, once I had renoved all the trims 🙂
Am 19.07.2024 um 22:05 Uhr sagte zacko_O:
Funktioniert es?
For me (MY17) only when opening the vehicle, not when closing it. The BCM is too old for that. I still have to exchange it.
Finally, I've finished today.
Now I can add all details
Wires schema. All wires 0.5mm except mentioned, for RH rear fog light will be on right inner side T4e/1 - T6bh/1(double check it).
Preset, all adaptations for FL BCM, but you can use it for preFL BCM.
preset
And video :)
Edited by zacko_O
Which BCM did you install?
Since the animation works when you lock it too.
The cable diagram is known.
5Q0937084EC
Okay, so only with an exchange. I have BCM lying here. Thanks
1 hour ago, zacko_O said:
5Q0937084EC
Did you swap to this BCM or was it factory fit in your car?
Swapped
Here I described how https://www.drive2.ru/l/681792318050668410/
Even I developed app to sync most of the adaptations
Edited by zacko_O
Vor 34 Minuten sagte ApertureS:
Haben Sie auf dieses BCM umgestellt oder war es bereits ab Werk in Ihr Auto eingebaut?
EC has only been around since the facelift. Cannot be found in a 2015 model. My 2017 or a 2018 doesn't have that in it either.
Therefore it needs to be rebuilt.
