Cold running
Hi there
I've just bought a 2015 Superb 2.0 PD170. The water temperature seems to stay rather cool - it takes 20+ minutes to shift off the bottom of the gauge, and then struggles to reach 60-70 degrees. If I get on the motorway it'll stay around 50 degrees. If I sit in traffic for a long time it will hit 80-90 degrees, but then when I start moving again it will drop to 60 degrees or lower once more.
So far, I've had the thermostat, the coolant temperature sensor and the secondary water pump replaced. The main water pump was done a few months ago. These changes have improved matters but not cured the overall behaviour.
Any suggestions for what to try?
If it’s a DSG the DSG stat is well known to cause temperature gauge issues. Do a search.
Happened to me on a 2011. Very cheap to obtain from Germany Autodoc the Mahle version.
Manual or DSG? If it's a DSG, there is a second thermostat that commonly causes cool running when it fails.
Thanks for the really quick replies!
Yes, it's a DSG 'box, so based on your responses that's definitely the next thing to try. I'll get that swapped and update you with the results.
Yup, definitely worth trying if it's not been done. It's surprisingly common I'm afraid 😕
Example of a similar Yeti with some pictures: showing the part and location:
@teacake
it should of been the first and cheapest part replaced
Even dealerships replace the main thermostat first which does not cure the problem.
Know of many that have been down this route and get stung🙄
Edited by DEL80Y
Yes, Del80y, that's potentially a lesson painfully learned. I've thrown nearly £800 and two weeks at this so far...
I'd be sure you have a common rail CR 170 in that 2015 (congrats on the car - the estate version of the superb 2 is excellent. I'm sure you'll love it when you have this problem sorted).
I expect you're right. I'm not yet fully up to speed with the model nomenclature with VAG diesels.
This is the thing that really gets me angry for a £20 part
Glasgow Skoda are still doing it to customers the now.
You know because "they have never came across this problem before"  AGAIN
Yup. The indy I take my cars to, who I completely trust, told me they'd called Skoda and said to them "Are there two thermostats?" and got the reply "No, just the one."
Finally got the car back tonight. All those people who identified the DSG thermostat as the culprit, give yourselves a pat on the back, because that's exactly what it was.
Thanks very much indeed for your advice, I just wish I'd asked for it before I had all the other parts replaced...
To " @teacake " - It is good to hear that the Problem is successfully fixed. It is good first to ask in this Forum for any Problems hereafter too ;)
Edited by tuningmania
Lesson (expensively) learned on that score.
Hi Teacake this sound like my issue, did you change the DSG thermostat yourself or a garage? If a garage I hope you don’t mind me asking how much did they charge?
Hi Luchese
I had a garage do it, because I'm a bit useless when it comes to the mechanical bits. I can't give an exact cost as it was lumped in along with some other jobs, but I'd guess it was about £80, parts and labour.
Thank you Teacake I am going to discuss with the garage this week. Do you know if this was showing as a fault when plugged in to the computer. Question is will either the DSG or the other thermostat be picked up as a fault?
Sorry, I don't know the answer to that, Lucchese. I'm guessing not, as if it had they'd have been led to it straight away rather than asking Skoda for advice (erroneous advice as it turned out).
Edited by teacake
@Lucchese - I wouldn't expect either thermostat to show an error on a scan. Mine certainly didn't when the main thermostat was faulty :)
Thank you, I will look at replacing the DSG Thermostat first.
DEL8OY I see you have changed your DSG Thermostat did you do this yourself?
A few of us have done our own including me. There are writeups on here I followed and maybe added me own. Please search.
Mad, isn't it? This cost me the best part of a grand.
Wow that's a lot, for a part that costs about 25 quid and maybe an hour to change it. Sorry to hear that man, I was lucky as I am under warranty still (only had the car just over a week), which is why I had them do it. Other than that I would've done it myself.
