Amundsen MIB2 Firmware Update
All check your PMs
  • Replies 4.7k
  • Views 900.1k
  Updating the software is going to reset or delete the installed codes ?  Like car play, voice activation etc
Hi all could someone tell me if I have a firmware update available, and what would updating achieve?
Part number 5Q0035874A
Hardware H24
Software 0245
Nav database 5L0051236E
0430
ECE 2015/16
Thankyou
Are there any updates for this HU - Columbus MIB2?
Octavia 3 model 2017 prefacelift
Tnx
On 05/12/2021 at 18:47, pab567 said:
I should be able to have it repaired but you must deliver it to me to Poland.
I appreciate it, but no thanks
Hello,
could someone please help me and send a link to newest software version for MIB2.5 Amunsden infotainment?
I believe it should be 0480, currently I have 0478.
Many thanks in advance.
Daniel
Hy @pab567 any update for this ? Thanks
Hi @pab567, great work, can you please help me with my system update, I sometimes have android auto or bluetooth disconnect problems, cheers!
0-02-05-e7a44a9a8e44ecc94c3ddabf18d4ce2dd97c7e96120f3c0da1d9368898204a11_45bad3bcfaf6d650.thumb.jpg.39d0c5411703d6724014c1beae7ff123.jpg0-02-05-edaa49a5cbc3e41710c5d4f58288506dc0df8ada5cdb7c2056525ccccb57bde6_36cceeca8086489d.thumb.jpg.38e578544c240a68bb28c08d8f1168bb.jpg
Sorry to admins for quote my own post, forgot to write car info
Skoda superb 2016
hardware: h30
software: 0359
Are there any firmware updates for my mib2  ?
2016 1.6 TDI optimal dsg
If these are official codes - no. The risk is only for hacked units with non-officially installed codes.
I don't have any firmware for your unit 😞
Is there a way to check the installed codes are official?
Tnx
Regards
Svet0
Go to Service Menu (long press MENU button) then FEC/SWaP codes  then Installed Codes. Paste the list of codes and your VIN here. Check if every code has your VIN inside.
Ok, I will paste codes and VIN soon as I get home!
Tnx
Regards
Svet0
but is there an update for this unit?how can i find out or find an update?
Either OTA (Over The Air) or contact your Skoda dealer.
Excuse me but what's over the air
excuse me but what is over the air, how is it done over the air?
When unit is connected to the Internet updates are automatically downloaded and installed.
VIN - TMBJG9NE9H0073310
Here are installed codes:
00060100
00060900
00060800
00060300
00050000
00030000
08300008
00040100
00070200
all valid in multimedia.
Regards
Svet0
One more check - entern each of them and check if VIN indicated there is equal with the one of your car. if yes then 99% your cods are official and you can proceed.
I did, and in all codes are VIN of my car. All with the same date and time and valid status.
Example pic of first code:
Today I will install update and report back.
Regards
Svet0
Then I believe everything is OK and you should not expect any issues.
