Amundsen MIB2 Firmware Update
@pab567Do you have any latest update for below setup
  • Replies 4.7k
  • Views 899.3k
  • All others pls check your PM for SW download links
  • I beleive what you have is the latest version
  • I have upgraded multiple units from 0478 to 0480 and have NEVER had any issues @Fix666 check your PM for download link
@pab567
Any update for this version please?
Check your PMs
Hi,
Is there any update for my device? Thank you
Hello Pab567, good evening to all.
First, sorry for my english.
Is there any update for my device? :
MST2_EU_SK_ZR_P0359T
ref 5Q0035864B
SW version : H28.28.133_STD2Nav_EU
Thank you for your help and availability. You are always here to answer.
Thanks !
ref 5Q0035864B
Thanks !
And Please, Anyone have a tutorial explaining the firmware update? Thanks in advance.
5 hours ago, pab567 said:
Check your PMs
Thank you.
Good evening, I packed the file and downloaded it to a USB stick. Then I put it in the car radio and it also indicates that there is an update on the stick. But when I want to apply it via the menu, it always shows an error that he can't find any of it. Do you have to install the update via SD card?
Hello @pab567 this is my mistake. Can you help me please?
I packed the file and copied it to SD card and USB stick. It doesn't work for both.
Hope this is the right info you need
On 31/01/2022 at 12:07, pab567 said:
Check your PMs
Worked fine, thank you @pab567
Hello all, my first post on forum.
Question about mib2 update, does it fix that 'autodimm 10 seconds' feature which allways needs to be reset after startup. Thats pretty much only fix that Im looking for.
And other thing, thank you all for the quality of conversations. Real pleasure to read 👍👍
Guy who knows @pab567
@SirDaff I am not aware of any bug with 'autodimm 10 seconds' feature, could you pls elaborate a bit more?
@pab567
Shure, I assume you know that function that Im referring to. If I select that automatic dimming (or is it screen off) after 10 seconds. It will work perfectly until I poweroff the radio. Setting resets to default (unselected) in every power on.
This is not a bug, this is a feature. It always you to turn screen black once after not touching it for 10 second.
@pab567 Oh ok.. so its not getting 'fixed' with updates. Oh well, I can live with that. During dark winter time I need to keep on map view  just because its not bright as radio (with station logos).
ref 5Q0035864B
Thanks !
Hi @pab567
MIB 2 ADMUNSDEN
device 5q0035874a
hw H24
SW 0252
Is there an update for me? and will it wipe any adjustments made via OBD eleven/
TIA
@pab567 will be happy for your help
This is what I have is there anything new that came out?
Device Part Number: 565035842
Hardware: H41
Software: 0478
Media codec: 4101.0.0.0
Tnx!
PM
On 09/02/2022 at 23:16, seanbrady49 said:
Hi @pab567
MIB 2 ADMUNSDEN
device 5q0035874a
hw H24
SW 0252
TIA
Hi @pab567would is there an update for the device above?
Hi @pab567 Can you please help me with new firmware and maps for my vehicle?
System information
Device part number: 5E0035864A
Hardware: 040
Software: 0421
Navigation database: V0395807NT0094 ECE 2020/21
Media codec: N/A
Thank you in advance.
