Amundsen MIB2 Firmware Update
33 minutes ago, crossbox said:
Yes please
Sorry, seems I cannot send any more PM's.
Didn't realise there's a limit.
Try to send to send me one, and I will see if I am allowed to reply to it, otherwise file will be linked to you tomorrow at some point.
  • Replies 4.7k
  • Views 916.2k
Hello,
I have a 2018 Skoda Superb with amundsen system. Attached a screenshot of the current firmware. Is there any update?
Thank you
Edited by Acrab
On 08/07/2022 at 22:28, varooom said:
There might be an update
Are you able to get "SW Train" version?
Hi @varooomThanks for the reply. I'm not sure what you mean by the "SW Train" version.
I can see that there are new maps available to download which I will do but for the 'Software' section it says this.
MIB Infotainment version check (MIB1 MIB2 MIB2.5 MIB2Std MIB2High)
Here you can see from 1m 30s+ where the menu is entered and shows the Hardware part number and the Software train version.
Rather than send any flash file, I would rather double-check to be 100% safe.
Hopefully you can see
MST2_EU_SK_ZR_P03xxT
Try to take a picture to very, and upload here
Edited by varooom
Hi @varooom
These are what it says when I enter the hidden menu.
First SW Train is '----' but if you go into the 'Version' section you get the other picture.
If I go into the logging section it shows the 2nd picture.
Thanks.
Lou.
10 minutes ago, lou3b said:
Hi @varooom
Thanks.
Lou.
You have a PM for 0369 version
Thank you! guessing that's the latest I can go up to on the hardware version I have installed
I am no expert on the systems, but if you are on 02xx / 03xx / 04xx then you stick within your SW band.
The hardware parts are different between the units, so risk of bricking is high if you load 04xx onto say 03xx base firmware.
I am sure there are ways to apply the "wrong" firmware versions, but I wouldn't risk that myself.
On 09/07/2022 at 20:32, Acrab said:
Hello,
Thank you
I am sure that your SW Train is MST2_EU_SK_ZR_P0472T
Please look here to verify, look around in update history if needed.
MST2_EU_SK_ZR_P0480T is available if needed.
On 08/07/2022 at 22:35, varooom said:
If you are able to show a "SW Train" version I can try to check
Potentially 0253 might be available.
Thanks. I managed to find 0253 and updated the unit.
Cheers
Looking also for an update which will hopefully help me with some problems and unrationally behavior of the touch screen of my Amundsen.
Many thanks
Many thanks
I am sure @pab567 will confirm, that the MST2_EU_SK_PQ_P03xxT has never been seen to be released in the wild.
So therefore, no update is available or even same/earlier version.
Unfortunately, I can have it confirmed 😞
Unrationally behavior of the touch screen are usually result of either faulty touch panel or front board, I have NEVER met a case of such issues related to SW 😞
I have the following Amundsen system. I would be grateful if someone can get me the latest update.
thanks.
Thanks for this infos, even if they were unfortunate
2 hours ago, Hairy said:
thanks.
MST2_EU_SK_ZR_P0253T is availble
I shall send a PM in next few minutes, packing your file for transport.
is there a firmware update for this , if there is is there any benefits
also can this be hacked for virtual sound and sub
thanks in advance
thanks in advance
1. Yes, MST2_EU_SK_ZR_P0480T
2. Maybe
3. No idea
thanks for your quick response where do i get the firmware
Assuming you don't have Canton, it should just need recoding to enable the virtual surround and sub :)
I'm sure Pab will provide you a link soon for the firmware.
thanks
PM with link to firmware sent
cheers
Is there a way to know what changes each firmware version introduces?
Hi.
I have the MST2_EU_SK_ZR_P0471T version.
Is it possible to download and upgrade to a newer version?
System 5Q0035874C
Hardware: H41
Software: 0471
