Amundsen MIB2 Firmware Update
Would someone be so kind as to provide me with the download link for this firmware?
Thank you
MST2_EU_SK_ZR_P0480
  • Replies 4.6k
  • Views 808.2k
3 minutes ago, Acrab said:
Thank you
MST2_EU_SK_ZR_P0480
I sent you link the other day, did you not download it?!?
Hello,
I sent you a private message yesterday telling you that I downloaded the file but I don't know where I put it or if I mistakenly deleted it with other downloads I had in the same folder, and now the download link you gave me doesn't work
Thank you
2 minutes ago, Acrab said:
Hello,
Thank you
Retry the link, PM if issues.
Ok, thinking about it I do have some glitches, so any update for this?
@RoddersUKyou should scroll up a few posts to see the YouTube video on how to get the Software Train information
That's the picture to tell you what file is needed.
This one.
9 minutes ago, RoddersUK said:
This one.
Yes
Available 2x updates, will bake the new 1440 version
MHI2_ER_SKG13_K4524 = 1382
MHI2_ER_SKG13_P4526 = 1440
Cheers, PM received. Will play later!
On 19/03/2022 at 09:57, pab567 said:
Check your PMs
hey, please help me too, with update. Thanks.
@pab567hey, please help me too, with update. Thanks.
0480 version is available
I shall send you a link in a moment
Wow, up to 1hr to do......lucky it's not really hot
Kind of a standard quoted value, actual time depends on hardware (SD Card speed and CPU/internal storage speed)
iirc mine was about 20mins
Ok, that's all done, there was 'N' on some things, I didn't change anything. I just let it do what the default was. Was about 20mins if that.
As long as the smoke stayed inside the car, all good 👌
Any chance of a link for a update if available and how to install thanks
Yes I shall send link in next few minutes
1 minute ago, DonJayDk said:
Like this ?
Yes this is correct
0480 version exists
1 minute ago, varooom said:
Yes this is correct
0480 version exists
Is it possible to have a link for it ?
Yes I shall generate a PM for you in next 3-5 minutes
Thank you so much man.
can this be updated guys?
