Amundsen MIB2 Firmware Update
9 hours ago, varooom said:
Hello,
Press and hold down your menu button for 10 seconds or so, then you will enter the hidden menu with Software Train information and update button for firmware.
Hello Varooom,
thank you for your response.
Now it should be fine ;)
  • Replies 4.7k
  • Views 898k
1 hour ago, arekszg1 said:
Hello Varooom,
I shall send you the update in a few moments
@varooomThank you very much!
Can anyone help me with an update for my 2017 Leon FR
Current version MST2_EU_SE_ZR_P0359T
I think the current version might be 0369...?
Yes Seat is 0369, will PM in a moment
hi.  do you also have updates to my version?  Thank you in advance
Yes it's 0253 version available for you.
Will PM in 5 minutes.
Hi, could anyone tell me if there is an update available for this?
@veggersHold down your Menu/Setup button for about 10 seconds, this is the hidden service menu (engineering)
Ah, ok, see below
Just now, veggers said:
Ah, ok, see below
0369 is available.
Sending link now in PM.
Hi Everyone, new to this forum. Bought a 2017 pre facelift Octavia last week and enjoying the drive. I am looking for the update for my infotainment system and came across this thread. I am wondering if someone be kind enough to provide me with a link for the update, Your help will be much appreciated. Thanks in advance.
It's also 0369 version, link to follow in a few minutes
Received with thanks. Much appreciated. You are a star.
Hi everyone, I am a new joiner to this forum. I want to install some SWaP codes, but my unit needs to be patched. Currently I have the firmware version: MST2_EU_SE_ZR_P0514T, 5F0035824C
H29.344.59_STD2Plus_EU on SEAT Toledo KG3.
@varooom, can you help me please with the newest version for my unit ?
Thanks a lot!
Thanks a lot!
I will send over 0516 version for SEAT, just be careful with installation with SWaP codes.
This guy is a genius!
Thank you!
hello, please help with upgrade for my kodiaq's mib2. cant update maps, and i think this is the reason. thank you
I will send a link for you in a moment
Hi, does mine have an update too?
Yes you can load 0480, will PM a link over
Thanks very much!
thanks a lot !!! will post result after map update
This is that I’m looking for
Can you send it to me too?
I can send a link to you
