Amundsen MIB2 Firmware Update
Would it be possible for my system to find something?1418452222_311110104_415068540791348_6367317015367555774_n(1).thumb.jpg.abe4155b0350ae745ad7c27b6d84ec53.jpg
  • Replies 4.6k
  • Views 776k
I will send link to 0369 update
Is there an update for mine and where do I get it from
cheers
cheers
I can send 0253 via PM, next few minutes
Got it thank you very much
This is the software on my MK3 pre-FL Octavia vRS. Can this software be updated?
Try holding down your Menu/Setup button to get your software train value, and this is also the location to the actual firmware update button.
Hi, is there an update for my Superb?
Yes all the way to 0480
Great, any chance to get the link via PM? (I hope it fixes my issue that time is sometimes 1 hour off. It's driving me crazy)
Thanks a lot.
Thanks a lot.
Yes, one moment
Hello, any update for my car? thanksIMG_7059.thumb.JPEG.8be9be20b7226907914ade415886794d.JPEG
hola hay actualizacion para este -muchas gracias
@ScleptzeR MST2_EU_SK_ZR_P0253T is available, and I will send you a link in a few moments.
@manu73 You need to hold down your menu/setup button to get into the engineering menu, you are looking for Software Train value (MHI2_ER_SKG11_K3343 for example)
buenas este es??
33 minutes ago, manu73 said:
buenas este es??
You should really write in English please.
MHI2_ER_SKG11_K3343
MU 1433 is available and compatible to update your radio
thank you very much can you send it to me
Already done, hopefully success to you
it gives me an error
Can you please translate for me
software update
error no data available.
enter a source with data to update the software or check the source
Just now, manu73 said:
software update
Can you take a picture of the file structure of the SD Card?
1 minute ago, manu73 said:
They are in the correct places (root)
It's formatted as FAT32 hopefully on SD Card
Was you in the screen with Software Train for the update?
If this fails, then maybe you need to borrow a PC to extract file's.
I tried with sd card and pendrive and it doesn't detect anything, any solution?
