Amundsen MIB2 Firmware Update
Unfortunately I don't have it 😞
  • Replies 4.6k
  • Views 852.5k
Okay, thank you, then i'll ask, do you have any update for my version then?
Hi! I have a 5C0035680B unit on a VW Transporter T6 with MST2_EU_VW_PQ_P0245T, any idea if these firmwares will work on this too?
Hello all, firstly thanks for this thread, incredible knowledge.   I am getting call drops after a few mins when in car play.  I was wondering if there is firmware upgrade that anyone has for this unit:
Thanks in advance.
@Deansie
Hi Deansie. I can update your unit to version MST2_EU_VW_PQ_P0480T.
It already has a color menu and I can activate Apple Carplay and upload all the swap codes at the same time.
If you are interested, please contact me at any time.
Regards, Joco.
Hi, I search to update from MST2_EU_SK_ZR_P0253T to MST2_EU_SK_ZR_P0480T with part number 5Q0035864A.
Can you help me?
@pab567 Can you help me?
Edited by Prem1
Hello I am looking for updated firmware for Skoda Octavia 2016 part number 5Q0035874B and current sw MST2_EU_SK_ZR_PO367T
If anyone could provide a link that would be great
thanks
Yes I know how to do it it is not straight forward unluckily. You can write me message and I can tell you. But if you want just new modern skin it is build in 369 you just have to switch the skin in developer menu.
Thanks yes i mainly want the modern skin so i will try 369 first then message you as it would be good to have it as up to date as possible
Do you know how to switch the skin?
Check your PM
Who wants to convert 02xx, 03xx to 04xx, write me.
3 hours ago, pab567 said:
Check your PM
Hi, I don't see the PM,
SOrry, the message was to @Chrisc83. For converstion from SOP-2 (02xx) or SOP-3 (03xx) to SOP-4 (04xx) you can contact @Joco776, I don't provide solution to make it (I can do it but I require unjit physically on my bench).
Hi is there an upgrade available for this?
Hi, I convert my unit from 02xx to 04xx, but the emergency not update by error, is important update the emergency? And can I change to the main menu see in square?
@Prem1 PM me.
  • Joco776 cannot receive messages.
The webpage says this
Any update for this version?
Hello all, new mk3 owner here.
Is there a worthwhile update with instruction worth doing to my Amundsen?
I have just done the maps.
Thank you 🙂
Hello is there an upgrade available for this?
Hi, randomly my unit keeps freezing after ending calls. Hoping an update may help.
Recently Browsing 1
