Superb 280 which oil
As the title says, what engine oil do I need for a Superb 280. I have some oil in the garage from when I had a VRS220, but I'm not sure if the Superb uses the same oil. I think what I have is 504?
  • Replies 60
  • Views 12.3k
  • 5W-30 for the 280; I've always used Castrol Edge.  The dealers will likely use/recommend whatever is cheapest to buy in bulk at the time (brand wise).    https://applications.castrol.com/oil
  • Just stick with the sticker. I wouldn't bother putting the plate into any sites. Stick with what Skoda recommended, unless the car is heavily tuned.
  • FYI, there are reasons people choose different oils. Let's take 5W-30. Simply put, the 5W part is the viscosity of the oil when cold, and the 30 part is the viscosity of it when hot. 0W is thinner
Don’t go cheap with the oil. I mean, use what the factory uses in terms of viscosity and VW specs. Brand is another issue, I personally prefer Motul, but as the car is under warranty I’m still using Castrol.
Castrol edge if stock, liqui moly top tec if tuned
Castrol edge shown on the skoda uk website, as well as 'genuine' skoda /vw group oil. Buy online as halfords is very expensive especially for 1l bottles.
Quantum oil from TPS is surprisingly cheap. If you go for the non-longlife (Platinum) it is ludicrously cheap and seems marginally better for the engine than longlife.
I note Castrol now state its Edge 0W-40 for the 280? I wonder why it’s changed?
Edited by numskull
  • 4 years later...
My 73 plate Superb 280 just had its second service with ŠKODA main dealer under its service plan and I was surprised to see they put 0W20 LongLife oil in. I thought these took 5-30?
But the VW 508 00 / 509 00 so 0w 20 FS IV is correct.
Ok fair enough, thanks. I was just a little surprised as its an unusual viscosity (IMO) and last time they put 5w30 in it. 19k miles on it.
after i saw they put 5w30, to the next services i came with my own 0w30 Liqui Moly TOP TEC 4210 LL3
@Ootohere
i can't see connection between 280 and IV
@MartiniB
Well maybe think.
Connection is not about being a 280,
it is any TSI after 2018 when they were WLTP Cerificated, 1.0, 1.5, 1.8, 2.0
& the TDI,s other than one that still used VW504 / 507 FS III
5w 40 FS III (long life) & III is 3.
0w 20 FS IV (Long life( & IV is 4.
I never named the oil.
Edited by Ootohere
@Ootohere
0w20 bottle in your picture is 508/509
280 sticker says 504/507 -> 0w30
@MartiniB Good. If VW 504 / 508 then 0w 30 or the 0w 40 that some places show.
What age is your car / engine?
EDIT, i see 2023.
Does @Tibbadog,s car not have the same sticker, and as it is then last time serviced they used the wrong oil.
But then that seems to be how things have been going, there are those that no longer have Long Life III
or VW 502 00 , 5w 40 FS Not Long Life oil for fixed oil servicing of TSI,s.
Some TDI,s from WLTP time were then getting 0w 30 FS III when they were previously 5w 30 FS III.
Still VW 507 00 rather than VW 509 00 0w 20 FS IV.
Edited by Ootohere
504/507 is 0W-30 and 509/509 is 0W-20.
It is likely that a certain region will only get access to certain engine codes - those engine codes may be specifically for 20, or 30 weight oil. As I found out with my 2020 vRS, there are some subtle differences (like the oil pump) that mean a slightly thinner oil is actually better suited for hotter temperatures. Certainly, stick with what is says on the sticker.
0W-20, really, is for emissions - it's just a shame that the engines are apparently optimised to run on it, rather than 30 or even 40.
From my understanding, the EA888 Evo4 is designed to run on 0W-30, whereas the later runs of the EA888.3 (like my car) is designed/tweaked to run on 0W-20.
On the above, emphasis on "apparently", very much apparently.
I do not claim to know more than the engineers that design engines, but I remain extremely mistrusting the claim that modern engines must run with such viscosities. The mechanical actions involved in a combustion engine have not changed from its inception.
You can have lighter materials, reduced tolerances and whatnot, but the basic process is the same*.
You can have optimized refining processes for modern oils, but their function remains unchanged.
My theory is that the reason thinner oils are recommended, or imposed, is purely to minimize friction to reduce fuel consumption and emissions, but this goes at the expense of mechanical longevity.
In my part of the world where the average car has +200k km, the results are terrifying and the reputation of the TFSI engines is ....below ground, together in good company with other modern direct injection powerplants.
Now I know I open a can of worms and a probable battle of words, but nothing can technically convince me otherwise of the fact that running a high-perfomance engine at high load with a -20 oe -30 engine oil with 25-30k km intervals is a recipe for a powerplant that will last more than 200k km without a major and very costly overhaul ....
I want to go at least 0W40 but the 504/507 standard is limited to -30, and I cannot find wether this is because of the presence of the GPF or just to comply with Euro emissions ... for now I am with shortened intervals, at least fresh thin oil is better than "well-used" thin oil, in my book ....
* when you tear down one of these engines and see almost razon-thin piston rings, and the pistons themselves light and thin as paper cups ... does not speak well of its capability for resistance.
I have read this whole thread now about 8 times and I still can't figure out which is the best oil for my 67 plate 280!
Depending on what site I use depends on what oil it says that I can use! 3 different options, some sites say one of compatible, another site says it's not! What is the correct Castrol edge for this car?
Edited by deedie
I use castrol edge 5w-30 LL in mine.
Look at the sticker - what does it say? My 2020 vRS (EA888.3) wants 0W-20, but FL Superb 280s (with the EA888.4Evo) want 0W-30.
I debated going up to 5W-30 or 0W-30 but decided against it as there are differences that mean the engine is tuned to run on XYZ viscosity (albeit for emissions purposes).
the 2 replies i have had to this query is a classic example of why this thread was so confusing!
and the fact that when putting reg plate into different sites, gives different replies. which is about as helpful as a chocolate teapot.
i will stick with the sticker suggestion. i just assumed there may be a reason for people choosing to ignore it, or the sites giving different options!
0W is thinner when cold than 5W - modern Euro engines don't tend to do well with heavy, thick oils at a cold start. However, whether it's 0W or 5W in the UK won't really make much difference.
The 30 part, the weight when hot, is more important. For example, my vRS runs on 20 weight, whereas most people like 30 or 40 weight. The thicker the oil is at temperature, the more protection it provides. In theory.
The thinner oils are, really, used to help with emissions - thinner oils are more economical. So, who cares about emissions, let's just put a heavy weight in to protect the engine.
The issue with this, however, is that it's not so simple. VW aren't stupid, and the engines have been adapted to run on this thinner oil - stuff like the variable oil pump has been optimised to run on the 20 weight at operating temp, and tolerances are also optimised. Sure, 30 weight offers better protection in the crankcase, but at what cost to the tighter tolerance bearings, etc? In reality, a thinner oil allows for a higher flow, which makes maintaining pressure easier. Less thick oil or more thin oil - same thing, really.
My car is/was tuned and does get driven hard. I debated long and hard (just ask @Ootohere) about going to 0W-30, but decided in the end to just stick with what Skoda recommend. I even reached out to several (respected) VAG tuning places and they all said to stick with the recommendation from the manufacturer. The difference in protection might mean my engine has issues at 150,000 miles versus 165,000 miles - but I won't have it then. Sure, the difference in oil might make a difference (for better or for worse) but I don't believe going from 0W-20 to 0W-30 is going to make any huge difference.
People use thicker oils as 'thinner oils are rubbish and offer no protection - it's all emissions crap'. Not all of this is untrue, but without being on the design team at VW and knowing exactly what changes were made to run on 0W-20, 0W-30, or whatever, I would just stick with the sticker. VW seem to have learned from this, as the earlier EA888.3 ran on 5W-30 and now the EA888.4 Evo runs on 0W-30, however I'm not losing any more sleep over it.
[disclaimer for all the... people... on here - as mentioned above, many things are a generalisation. Talking about viscosity grades and centistokes probably isn't going to help OP.]
Oh. Get VW spec too. There is a difference between an oil being suitable for the specification and being approved for the specification.
Thanks. That's helpful to understand
Can't find the bloody sticker that tells what the recommended oil is! Any idea where it is likely to be?
@deedle If your car is a 67 Plate registered between September 2017 & March 2018 then it was as the WLTP was introduced.
They many have started filling with 0w 20 FS IV pre WLTP testing, but prior to that it was 5w 30 FS III.
After Skoda oil recommendation changed there were still dealerships using the oil they had for years previously.
Your engine was not shown when they published this.
Edited by Ootohere
