2008 fabia 2 1.4 petrol not firing up
hi all
wondering if anyone can help my wife went to use her fabia after about 8 days of no use and it won't fire up it will turn over but that's it all the lights on the dash are normal and I used a obd2 reader and it did not show any codes I can hear the fuel pump when I first turn on the ignition I've also tried to jump start it from my car but no luck.here is a video of what it dose. also its exactly the same with or without the jump leads so I think the battery sounds ok
Thanks Nathan
I forgot to mention the car has just under 80k miles and had a full service including cam-belt & water pump in November 2019 and small service in november 2020 and has only covered about 7k since then
Can't say but it certainly spinning over fast!
I am sure you will have checked, but your petrol has not been pinched has it?
to be fair i did think that but its showing 1 bar and the dash is saying 50 miles also im right at the bottom of a cul-de-sac so i dont think  anyone would have the front to sit on my drive and drain it.
 its the wifes car so I dont no its limits as to how low you can take it
 ill chuck a jerry can full in it tomorrow and see if its that
When it got its cambelt replaced, the small cam<>cam belt was also replaced and any tensioner and roller that were "aged"?
Edited by rum4mo
I couldn't tell you to be honest i just know  it was the cambelt and water pump
Did you get some petrol into it and it started okay yet?
I was just a bit concerned about the speed at which it is being turned over by the starter, I can see that you were using jump leads/pack, but even so - I hope that I'm wrong.
hi i put about 3lts in it that i had in a can in the garage but still no joy. it seems to be the same speed with or without the jump leads on i checked the battery and its showing 12.2 but it must be down a it due to me trying to get it started
i took the top cover of the the cam belt and it all looks good from what i can see there
A quick compression check would clear your mind of any dark thoughts.
yer ill have to get it to a garage once we are allowed out again lol
how can i tell if the fuel is getting to the engine without having to dismantle much
so i just went out and disconnected the fuel lines and turned the ignition on and the fuel flowed fine
so i thought i would check the coils  i took the airbox off noticed a wire that runs across the coils had been rubbing on the airbox and was partly bare so i taped it up and tryed to start it and it started so i put the air box back on and just had a quick drive around the block and seems fine and started fine when i got back so not sure if that was the problem as i cant see it shorting as the air box is plastic
ill see how it gos in the future but i cant see it getting used much for a good few weeks with all that is going on and my wife is working from home maybe ill use it for work instead of mine sometimes
anyway thanks for your replys everyone
cheers Nathan
