Rear Suspension Information
  • Replies 80
  • Views 27.8k
  • The point is there are too many variables involved if you measure off the ground. But I've pretty much given up on you seeing sense here, I'm posting for the people who find this thread in the future
  • Exactly the same reason why I've invested in sorting the rear suspension as not a chance of finding anything similar in Mk3 superb for the 25K I paid for mine when it was 3 months old with 3K on the c
  • To add some info to this.    Just replaced the original rear shocks and springs in my 2013 170 4x4 combi.   Had standard chassis with weight range 7 springs as the pics show.
Replaced with bilstein b3 springs and b4 shocks.
Bilstein b4 number 19-151069
Bilstein b3 number 36-148257
Drives really nicely and sitting at correct ride height.
Edited by rover220
  • 3 months later...
I just wanted to add to this the correction that a damper will not change or affect a vehicles ride height unless its the wrong one for the vehicle and has no bump travel.
The 10mm difference must be an error or different wheels/tyres if the dimension is from the ground and not the wheel centre.
Something I have recently learned on the Octavia and Yeti, not sure if it applys to the Superb, if a towbar is specified as a factory option then they fit stiffer rear springs.
Gas dampers do have a spring effect which adds to the coil's stiffness. This is quite obvious if you compare the stiffness of a new damper to an old one.
They will have no effect on the static ride height.
Dampers are measured by their ability to limit oscillation not by a spring rate.
They have a (small) spring stiffness as well as the damping function, they will have a small effect on ride height. Read up on Hooke's Law if you want to understand it more.
Some background reading on the topic of gas dampers: https://web.archive.org/web/20140102200021/http://millingtoncentralhs.scsk12.org/~jkasper/Site/Homework_handouts_files/Shocks Monotube.pdf
Especially this paragraph:
Quote
As the piston moves down, the fluid pushes against the floating piston and compresses the gas charge underneath it. The gas is actually nitrogen (air with oxygen and moisture removed). This creates a sort of “air spring” effect that keeps the fluid under constant pressure to reduce foaming as it flows back and forth through the orifices and valves in the piston.
This is a nice explanation of the effect of combining springs: https://www.flinnsci.com/api/library/Download/6b84d135cc974a8a9ae07a7289fcd79e
I am fully conversant with Hookes law thankyou and have been for 45 years and as a design engineer regularly used it.
But even without that knowledge, simply common sense and having had oily hands working on cars for even longer than that I would know that a vehicle shock absorber has no influence on the ride height, laden or unladen. Heck I knew it at 14 and by 16 fully understood it and could have explained it to anyone without needing to quote Hookes law which by then I could have, but if you want to carry on believing it then its no skin off my nose, I was more concerned that others might read what you said amongst a very good and informative posting and believe it because clearly you had done lots of research.
You are getting confused with the instantaneous transient spring rate which can be infinitely high with very stiff dampers during turn in and will cause very high transient roll stiffness but will have absolutely no effect on ride height in steady state conditions, when not resisting vertical motion the dampers have no effect to the spring mass system and carry none of the weight of the vehicle, 100% of it is supported by the road springs.
Edited by J.R.
I too am a design engineer FWIW. There's a compressible gas capsule in the damper. This is a spring by any definition. If you want to believe otherwise that's up to you. Not all dampers are monotube gas type, particularly on older vehicles (Bilstein's original patent on the technology expired in 1971 and up to that point they were the only company making this type), so it's certainly plausible to think from experience that there's no spring effect. I can say with confidence that the Superb 2 sits on a monotube gas type, which does have that compressible gas capsule, and therefore has a spring constant of its own which will affect ride height.
I've seen this happen myself on two different vehicles when I've replaced the dampers: the ride height measured from wheel centre to top of the arch increased after fitting the new dampers. It was also quite obvious from the condition of new vs old dampers. The old ones could be pushed down easily by hand and didn't recoil once pushed down; part of this is due to the fluid being worn and the holes in the damping element being worn, but the other part is that the seals will have worn on the gas capsule and it will have lost pressure and no longer function as a spring. Any new dampers of this type that I've bought have had a wire holding them slightly compressed, and they've immediately popped up when this was removed; after that it was impossible to push them down by hand. Pretty typical of a stiff spring element.
Make of this what you will. Technology changes, and what was once common sense might no longer be valid.
Further, the tables I compiled from the part numbers bear this out.
Three of the four Higher Chassis weight ranges share springs with the Standard Chassis (3C0 511 115 AF, AG, BL), yet there's a specified 10 mm difference in ride height. The only other component that can affect ride height is the damper, and the two damper P/Ns for the Higher chassis are unique to that variant. QED.
Understood, it was the mention of the wire holding the shock absorber in the transport position that swung me.
A modest Question.
As you guys have probably have forgotten more about springs - shock absorbers than I will ever learn.
I have  2.0 tdi    II  estate  , see enclosed photos of badge .
 90% of the time driving with 120kg of tools-eq in the luggage (rear) . can you give me some advice of where to go for a better solution than the standard ?
I might be reading wrong , but I find no 1J.. Or OY.. ?
I am more of a fast comfort driver . so i want to be more near standard ride height .
1 hour ago, ulfnilsen said:
A modest Question.
Most of the suspension related codes are not printed on the option label, only the one for front damping. In your case this is G07 which means it's standard chassis. If you sign up to erWin you can pay to get the full list of PR codes for your car, or a friendly dealer might tell you what's fitted. Another thing you can do is jack up the car and see what paint marks are on the rear springs - they can be cross-referenced with the table I attached to the OP.
9 hours ago, ulfnilsen said:
A modest Question.
The code L30 means that you have front springs with OEM part number 1K0411105BP
You can confirm this if the front springs are marked with 2 orange dots and 1 white dot, or 1 red dot, 1 white dot, and 1 red dot.
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2014/drive_standart/768/hg_ug/411/subcategory/411001/part_id/2561497/lang/e
Your rear springs may have OEM part number 1K0511115DE
You can confirm this if the rear springs are marked with 1 white dot, 3 orange dots, and 1 brown dot. Code 0YE would also confirm that your car has these rear springs.
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/SUP/year/2014/drive_standart/768/hg_ug/511/subcategory/511000/part_id/2561497/lang/e
Edited by Carlston
Thank you very much  for the reply guys.
I got this from a local dealer
0YF            Gewichtsklasse Hinterachse Gewichtsbereich 6
1AT            ESP                                                        V9
1CM            Fahrzeugklassen-Differenzierung -3T0
1D0            Ohne Anhängevorrichtung
1E0            Ohne Aktivkohlebehälter
1EX            Spezielles Typschild für EG
1G0            Ohne Reserverad
1JA            Dämpfung hinten, Basis 1
so with my extra 120kg  ( + i have fitted Westfalia trailer hook , maybe 15-20 more kg )on the rear. which weight class would you recomend  7-8-9 or ? and shocks   heavy duty ? (1JB).
If i change shock absorbers on the rear , is it then necessary to do the same on the front ?
Sorry i forgot
I have even trown in a sparewheel and a jack .
27 minutes ago, Carlston said:
That's all already in the table I posted in the OP.
1AT            ESP                                                        V9
1G0            Ohne Reserverad
So 0YF if I remember correctly (phone won't open the pdf for some reason) is weight range 6 and 1JA is standard chassis, same as my car. I have the OE towbar and two child seats, and found that even with new springs and dampers that the car still sagged by about 20 mm. I recently fitted a pair of MAD auxiliary springs and it now sits at the correct height.
If you think you need new parts anyway, you could try going to a higher weight range in the same chassis category. From a quick glance at a parts catalogue it looks like there are fewer combinations for the front: it's probable that each front spec is grouped with a few rears. I'm not sure how they are grouped though and I haven't had the time recently to research it.
Thanks for the replys
I have one's seen a  ETKA list where the different weight classes where described by weight (load) but have not been able to find it again...
But as Chimaera have done , maybe it woud be better to buy som of these MAD springs ? I will contact these guys an askif they have a suggestion.
...maybe it would be better to buy some of these MAD springs?
MAD springs will have a very negative effect on the ride quality.
No they don't.
My MAD springs make no difference to my handling, but they allow the car to sit at the correct height with factory removable tow bar and retrofit of AGM (heavy) secondary battery as fitted in the boot on the V6 Superb, but saying that, I am now too old to spank it and have winter tyres all year round so it would be drifting in high speed hairpins anyway.
It has the standard springs but B6 shocks and the MAD springs. If I need to change the factory rear springs, I would fit the matching springs for the B6 shocks. Other than the springs, everything else I fit is genuine.
15 minutes ago, Carlston said:
How exactly does reeling off a list of Skoda part numbers support an assertion that fitting auxiliary springs made by a different company will "have a very negative effect on ride quality"? Yes the auxiliary springs will make the ride a little stiffer because the effective spring rate increases but it's not a "very negative effect", and is easily canceled out by the fact that the car is more stable on the road, and quieter because the suspension geometry is working properly and putting the tyres on the road correctly.
