Skoda felicia overheating problem
On 28/09/2020 at 11:40, Papez said:
Factory installed AC has dual thermoswitch - 95°C for slow speed, 102°C for high speed, independetnt on AC which switches fan based on operation and pressure.
When you turn on the a/c the fan is spinning on the 1st (slow) scale or the 2nd (fast) ?
When you start the car and after few minutes the fan starts due to heating it spins on the 1st scale?
  • Replies 87
  • Views 8.1k
  • I didn't ask about YOUR opinion. I specifically asked HIM. HE can answer for himself. I want to know what is HE thinking about running the engine without a thermostat.
  • That doesn't go well with I call my Felicia ''Trusty''  😍  because i trust her
  • I will refresh your memory, in previous post you said that you will not answer to innuendo and blah-blah but here you are like a f*** creating one for me without a reason!
As long as ac is on when the car or the ac condenser is cold the fan spins slowly
Once it gets hot it spins really fast and never get colder but overheats pretty quickly
But on the high way at a hot day and 140km\h it never overheats it gets cooler actually
On 02/10/2020 at 11:20, Thefeliciahacker said:
The way the thermostat works is quite weird.
My ac has the option to kick the fan in speed two independant of the coolant temp.
Yet again the coolant DIRECTLY controls speed 2.
If it was retrofitted that way I do not know.
All I know is that I got the car that way.
It works and very good shall I say so I dont plan to change.
The only thing I want to know is if the AC should have control over both fan speeds.
What exactly what i have
I know the disadvantages of a removed thermostat
****y fuel economy
More engine wear
**** you catalytic converter
And
More carbon build up
But i dont want to install it till i know that the cooling system is 100% healthy
That is for sure,on the Highway (National Road called here) you have no problems but when the traffic starts the temperature rises very fast.
Moving at high speed can deceive you that there is no problem,i have face it in the past twice, the second was when i was in a mountain route when everything was looking fine (the problem existed but i couldn't see it because the indication on the gauge was below 90 'C due to cold weather) but when i reached the city and the traffic began the problem occurred and panicked me.
On 03/10/2020 at 22:40, D.FYLAKTOS said:
...but when i reached the city and the traffic began the problem occurred and panicked me.
That doesn't go well with I call my Felicia ''Trusty''  😍  because i trust her  :handshake:
8 hours ago, RicardoM said:
One month ago you suddenly felt the unneeded urge to reply to a 5 year old post without having a basic understanding of PCV.
I will not bother myself answering to your innuendo. You don't want to learn anything. You just want to stir trouble.
Learn the basics,this is  @Mohamedelbna thread and don't ruin it with flame posts. I have my car for 20 years driving it 5-6 days per week and has more value than you.
Keep your attitude when you car is broke or when the Life "turns the card" for you.
After that annoying interference let's turn back to the thread, so @Mohamedelbna any good news from your car?
Edited by john999boy
Tidy up
So i found a fan with its shroud its for hyundai elantra its 2 speed with dimensions of 44cm * 35 cm i might install it in a day or 2 when i have the time
I will test it if it is good with ac i might install the thermostat and problem solved
If not i will get back to square one
THERE WE GO AGAIN
NO GOD NOOOOOOOOOOOOOOOOOOOOOO
2 hours ago, Thefeliciahacker said:
THERE WE GO AGAIN
My friend . Its the sad truth
You take it all in
On surrender from the beginning
You take it all in
No I'm not talking about your issue. I am talking about the war ready to break out between two of our beloved forum members.
Oh **** i forgot
9 hours ago, Thefeliciahacker said:
THERE WE GO AGAIN
Rest assured. I have nothing against somebody who is so obsessed of his car as if it is his girlfriend. A good psychiatrist would know how to schedule his anger management therapy.
I'm sure it won't come to that but if it does, then I'll be the winner! :bandit:
On that note, we can call an official truce and normality will continue. :thumbup:
On 06/10/2020 at 16:02, Mohamedelbana said:
Oh **** i forgot
Some guys have life only via their computer, without it are nothing and any internet connection failure turn them to psychotropic drugs.
By the way @Mohamedelbana have you ever though to install an electric fan?
So some it's OK some say NO.
Oh **** i forgot
any news friend
So i installed the elantra fan its much much stronger but still have the same issue
At high way speeds like 150 160 km/h the engine is cool even with ac is on any open road engine is great and no overheating
But at the city its the same problem but it didn't get to redline its just a smidge over 90 then i get afraid and shut down the engine
When i open the reservoir the water gets out
Alot of it then i top it off and go stays some time at 90 then gets higher and repeat
I think i have air in the system
Why open it? You want to lose coolant and get burned?
No. The cooling capacity is not enough.
I open it cuz when i feel the fan with me hand its just warm air when i release some pressure the air gets very very hot
So what is the solution?
  • Sponsor
Has the operation of the coolant pump been established as being OK? (Forgive me please for not going back right through this thread to see if this has been discussed)..
Its o kay bro the important thing is to know something useful from my experience and not just you every felicia owner
I think yes the water pump is good i just replaced it the old one was leaking but no improvement
Edited by Mohamedelbana
Forgot to add some information
exactly
first of all 160km/h is a bit too much for the felly dont you think.
My car with ac in the city will run a tad over ninty its not that big of a deal.
Dont open a hot tank man cause one day you will regret it.
On 17/10/2020 at 09:19, Thefeliciahacker said:
exactly
160 is flat out i know but ppl here in egypt complain about their cars overheating from going above 120
For me its the opposite
any news?
