ocatavia vrs diesel re-map 0-60 times verses stock etc
8 hours ago, shyVRS245 said:
Tony a serious question is the fuel economy (not your priority granted) better after the remap compared to the tuning box?:wondering:
Its not notable different
https://www.fuelly.com/car/skoda/octavia/2017/themanwithnoaim/656953
Check for yourself remap was done end of Feb2000
Edited by themanwithnoaim
i would say when I had my box on, my fuel economy was around the same.
Only thing I noticed was the amount of regens the car appeared to increase, especially active ones. Since removing the box, they appear to have calmed down. Can only assume it was due to the additional fuelling.
8 hours ago, Jimbo1971 said:
makes sense that, re-map plus rolling road is the way to be sure what you are getting.
cheers lads
Errr not really
You can see a 8 to 12% increase in bhp with the same car in higher gears. Run a car in 3rd then run the same car, same day in 5th & you'll see a more powerful figure. Always when looking at a dyno printout check the mph, its a tell tale sign.
ok will do,
emailed AVON TUNNING anyone used them on here?
@smokeyshiva
From one of your posts you see to not be aware of Switchable maps.
I used a couple of tuning boxes on my old Ibiza TDi.
The first tuning box used a hose to detect airflow amongst other connections, and was quite on/off in power delivery. It was a pain when trying to cruise on the motorway so I complained and they sent a replacement that was all electric connections, and that worked a treat on my 90BHP TDI.
I also had a remap from Angel Tuning on my Mondeo TDCI. That was very good from my perspective, but it was an off the shelf map, not a custom map.
I think people are a bit confused between remaps, and custom maps.
A remap where a car is tuned, then those tuning settings are recorded and programmed into other similar vehicles, is an off-the-shelf remap.
A custom map is going to be unique to a particular vehicle, and to do that is likely to be expensive and take a few hours setting up and tuning.
I'm happy to concede that a custom map may use an off the shelf map which is then tweaked after installation to suit the a specific car and the customer's preference.
But a straight remap and then a "Ta-dah!" rolling road confirmation of power gains is not a custom remap, IMO.
For the record, I was happy with both the tuning box and the remap in the different vehicles. They did the job I wanted and didn't cause any problems, however simple the tuning box was internally.
The benefit of the tuning box is that it has a resale value after use.
Edited by EnterName
perfect cheers for the info, that's what I was after someone who has had it done for a while :)
