How To - Reverse Camera Fitting Guide
  • Replies 202
  • Views 101.3k
  • Nice guide, shame you didn't write it two days ago when I started fitting my camera   As I did a few things differently, I'll add some extra info as it might help others. I used an OEM/orig
  • If this guide is useful please add a like
  • @EnterName - I wouldn't worry. They've probably got a few suppliers for the camera unit but as long as the handle is the correct shape, I'm sure it's fine.   In other news, I've calibrated t
That is an amazing guide @weyland, thanks for posting. :thumbup:
@weyland am I correct in assuming that no coding was required? It was simply plug and play? Even though your car never came with the camera?
Edited by mfizz
@mfizz This camera is plug and play, I think the harness has a big part to play in that. The media unit instantly recognised the camera and it worked straight away :thumbup:
Thanks for a great guide.
But, how TF do you feed the cable down or up the boot lid?
Have you got it through the rubber gator? If so you need a thick wire or rod to push it up the side - you can then grab it half way up by the heated rear screen harness, pull the wire all the way up, then feed it through to the bootlid.
Getting it though the gator can be tricky, again a rod and patience is the key :thumbup:
Edited by weyland
Embarrassingly, at that point I hadn't read your guide properly and hadn't removed the vertical window trim piece (mines an estate). This was a pain to remove due to one little plastic plug holding it on at the end. Anyway, removed it and did as you said using the blue wire from a piece of twin and earth. Job done 👍 I routed the cable as langers2k suggested which worked well for me.
Another suggestion for forcing it though the gator - a tiny bit of washing up liquid to make it more slippery 😁
Thanks again for taking the time to post the guide. This will make hitching up the caravan much easier!
Hi @weyland
Just by chance, have you a clear image of the rear of the camera you fitted?
I ordered one from the link you provided, however the camera I received is not quite the same as the camera in their description.
I think it's just a slight product modification, but I'm wondering if your camera is the same as mine, or subtly different.
Here's what I mean.
The three cameras possible to be ordered are A/B/C taken from the AliExpress link. (I've ignored camera C as it's clearly completely different.)
image.thumb.png.5f5036fee03f8289b5c523530bbcabd3.pngimage.thumb.png.5cb67831aeb269edefdcc05487526abe.png
And here's what they sent.
image.thumb.png.1c1d32fd0447adadb84f6b3c384570ed.pngimage.thumb.png.a7960bd71cf0af1f96734940156b9b02.png
The profile and dimensions of the camera (the important stuff) match Camera A. However the back wiring image seems to match Camera B.
It's not an issue, but it did cause a minor "Awwww Hell!" moment when I first looked at the camera. :D
I'm wondering if there are a few different suppliers of this camera, and they just send what they have, so long as it works and fits.
From the other side, my camera appears to be the same as yours, so I guess it's just a slight difference between their product image and what they actually send.
Thanks. :)
6 hours ago, EnterName said:
Hi @weyland
Hi, I wouldn't worry - your current boot release harness will plug into the block in the middle to provide the normal function, and the wire on the left with the purple connector is the only one you need to feed to the front and into the replacement media unit harness to provide all of the reverse camera functionality :thumbup:
Edited by weyland
Thank you all, mine is now fitted.
About 3 hours, less if you subtract the time spent staring at it and swearing!
Things I have learned:
On an estate you do have to take lower door trim off, but not necessarily the upper one;
Some of that plastic coated spring which is designed to hold net curtains is fantastic for feeding through the wire;
Go shopping before you start, not halfway through.
:biggrin:
Steve
Hey everybody!
Does anyone know, if the camera fits the superb 2017 mk3?
thanks! ;)
Hi mate, best thing to do is measure your current handle to determine which size and style you need
My car is a 2017 estate and it fits and works perfectly.
Steve
Thank you everyone for this thread. Incredibly helpful in getting my reverse camera fitted :)
:biggrin:
Steve
Just Saved me about a tenner thanks :)
Thanks for the guide, this hadn't even crossed my mind as something I could do but it's something I'm gonna :)
Will wait until picking up on Saturday just on the off chance it already has the reversing cam, (I don't think it does but I've not seen the car in person)
Does anyone know what the stock is usually like on Ali Express? Currently non to ship from Czech Republic but do have them from china. Would prefer from Cz purely due to shipping time.
Alan
Get it from China, it'll be fine -  It will take 7-14 days. I'm unsure why they have different warehouses for certain things as you're essentially ordering Chinese made goods, direct from China which is why everything is so cheap.
Oh, and you're more than capable of doing it. It's the thought of it that puts most people off - once you get stuck in it's quite straight forward, just take your time :thumbup:
More and more of the production is shipped to EU warehouses ordered by the reseller once you click "buy it now" and dropshipped directly to you, the manufacturer sends out pallets & containers at a time & doesn't get involved in small orders, the reseller never physically sees or touches the goods.
That said for smaller items ordered from EU warehouses they often still come direct from China because of the subsidised shipping rates but they are probably held at a dropshipping warehouse there.
There are also re-distributeurs (there is probably a correct term for it) that recieve large parcels from manufacturers, an example might be the glasses you buy on line from a seemingly UK or EU company that is no more than a website, they are made in the factory in Pakistan or wherever and shipped in bulk orders to the redistribution company who then send them out by the postal service.
And then you get Amazon doing all of the above for sellers not even on their platform, I have bought security cameras from Ebay supposedly in stock from a French seller which were sent from China to Amazon France who put the original box inside one of theirs with the Amazon smiley logo with loads of paper filing and then delivered it to me.
I have bought 2 dashcams from Ali-express and they arrive withing 10 days.
Just to triple check before I order (found a photo of the car in reverse and it doesn't have cam), its the MBQ Wire + Camera A version I need isn't it? To be clear it's a 68 plate VRS hatch :)
Guidance appreciated :)
Facelift cars take camera A, if it's the harness shown in my pics (piggy back) it'll be fine. You should also get the stereo removal tools to release the media unit inside the glovebox
Great thank you. Ordering now :)
