Memory module for Start-Stop button
I got the buttons out but the cable was way to short to get disconnected and reconnected.
I eventually solved it by just using OBD11 and coding the start/stop out. Seemed to have worked.
  • Replies 59
  • Views 28.9k
  • But your start/stop button is on the wrong side (like the steering wheel 🤣), the buttons on that side of my car have longer cables too.
  • @310golfr @gav_is_con i own OBDEleven and have already changed several of parameters, but i can't accept disabling Start-Stop completely - for my taste, by default OFF, but still possible on
  • Thanks a lot for the help, I got it done yesterday. Seems to be working great.   It did hurt my fingers, a lot of force was required, I was a bat scared to damage something but in the end I
obd11 worked ok on a 2022 model ?
did you code it out using the temperature or voltage method in the long coding or can it be done with the app ?
It seemed to work but after the car was stationary for a couple of hours, it stopped working.
I used the 'app' in OBD11. Guess it didn't stick.
And yes, 2022 model.
if you peel the rubber gator on the gear stick back, you should be able to get your hand in ,  push the button up and disconnect the wiring plug
with your hand in there, you should be able to hold the wiring connector and connect the memory module with the other hand
I'll try that next week. Just need to figure out how to get the gaiter off (on a manual you can twist the gearknob of but that doesn't work a DSG)
Coding of the start-stop function is no longer possible from MY 20. Regardless of whether you use the app or manually. It's only possible by module.
I got the rubber gator of, but still no room to put my hand.
I'm just about to give up 😪
trim with leather can be raised higher
How do I get that part loose? I've been trying with a prying tool (plastic) but I can't get the trim loose.
@TL@
i lifted it by my fingers, it sits very tight
You pulled it up from the inside then (fingers in the hole of the gearshifter)?
yes
It did hurt my fingers, a lot of force was required, I was a bat scared to damage something but in the end I managed without breaking or scratching anything.
I was able to fit my start-stop memory module by simply removing the switch panel.
Had enough room and length to fit the module.
1670079187_Screenshot_20210812-1940042.thumb.png.bd6f51670376426fa493cb74ddf34f3e.png
You don't have to pick the button, just remove the entire panel like shown on  my pictures.
@TL@
ok I think I can't do that so will take car into skoda dealer
Edited by brsk
It's not hard, just give it a good pull.
  • 3 months later...
On 12/10/2020 at 13:23, MartiniB said:
1 - Brown
2 - Green
3 - Gray    *
4 - Red 1
5 - Orange 1
6 - White    *
7 - Purple    *
8 - Red 2
9 - Orange 2
10- Yellow
Thank you very much @MartiniB! I've bought S/S memory module for VW Passat B8 thinking it is the same (connectore looks same), because it was offered much cheaper. But i't didn't work with my Superb MK3. I removed the heatshrink in the middle of cable and the PCB looked exactly the same as yours, so I only swapped the pins in the connectors according to this pinout and it works like charm! (my cables are all black, excecpt theese that goes through the PCB, they are yellow - red - white instead gray - purple - white).
On Kia’s, if the button remains pushed down when the car is started it defaults to off and stays off. No ill-effects were reported. I’m sure there are more elegant ways, but I saw someone on a Stinger forum “bodge” it with a tiny piece of heatshrink wedged into the side of the button. Was almost invisible.
No idea if Skodas work in the same way? Just throwing it out there in case someone wants to experiment…
Would be grateful is someone can point me to an video or manual how to pull out the buttons.
Already try to lift the leather around the gear stick. But I'm afraid to use much force , don't want to get squeaking noise because of broken clips.
Edit: Found it....
Edited by Samo78
After month of testing this module, I am little sad about it. I am experiencing the same issue described in this thread. Sometimes after I manually enable start-stop manually by pressing the button (shutting down the engine), module after about 2 seconds disables start-stop unexpectedly (effectively starting the engine).
Did someone fix this issue? Maybe some capacitor or resistor needs to be changed on the PCB?
Seems odd you press the Stop / Start button to enable the system.
The button is to turn off Stop / Start and therefore it will start your engine up!
The symbol is @ off
And the manual should state that pressing this button disables the Stop / Start, so keeps engine running 24/7 if fuel allows.
very smart, and what happens on second press?
