Lane assist is dangerous
Correct, only ACC hold the Speed Downhill
  • Replies 379
  • Views 64.5k
  • Trouble is with this, you're unlikely to get many contributions from people saying e.g. "I was busy on my mobile whatsapping a hilarious youtube link to my mate Dave when the XYZ safety system cu
  • It is the one thing I like missing from my old Octavia................ too much unnecessary 'technology'.   If I get stuck in traffic I can turn my ignition off, and I like to stay awake and
  • I turn mine off, and Start/Stop, as a matter of routine when I drive off. I don't want even a slight tug on the steering wheel when I'm driving.   As for indicating when changing lanes, you
ACC will maintain the speed to around 5-8%. I use it a lot - doing 30mph it will go as low as 28ish before accelerating properly and go as high as 32ish before braking properly.
Normal/dumb cruise will only control the minimum. At higher speeds it does a good job of the maximum (engine braking, wind resistance, etc) but is a bit hit and miss.
Obviously with ACC you can set follow distances, as well as how fast it acclerates, etc.
11 hours ago, Exkiwi said:
That is not what was said and is a doctored quote I have further explained but if you are going to quote people put what was actually said as the quote and not alter it to suit yourself
I can't claim credit for that - it was all @Paws4Thot
"I hired a car without it and wandered all over the place as was so used to it keeping me in lane I forgot and had to concentrate a lot more" - you forgot you had to concentrate to keep two tons of metal going in a straight line at 70mph. Gotcha. I can see now why you were upset at the edited version.
Also FYI, maybe check images before uplaoding them to the internet? Mike Ehrmantraut from Breaking Bad seems to be in some of your infotainment photos.
That's not my experience on numerous cars including two Skodas. My dumb cruise control pretty much matches the set speed. The only time it struggles is going downhill just like it does if you were trying to control your speed manually, either by braking or changing gear.
??????????? I dont know what you mean about photos. Only hands holding the phone reflected.
Edited by Exkiwi
