Bolero MIB1 Update Help Please!
Thanks, yes that's exactly the file I used, it is bit by bit identical (same md5 hash) so it must be a problem with my unit, or my SD card.
Will try another SD card when I have some time.
Thank you anyway!!!!
Or, maybe any other ideas on why this might be incompatible? The SW Train is exactly the one like in most other screenshots here and MIB Helper also states that this version (P6320 MU0490) is the right one to use for that existing SW Train. It is really strange...
Thank you again
  • Replies 248
  • Views 35.8k
  • Guys you must post your system model number and SW version first...
  • Downlad link you both have on PM. To get Android Auto you must have both display and glove box unit exchanged. If you are interested pls contact me on PM.
  • 5E0919605H is MIB2 screen so glove box unit must be exchanged as well
New here and like many I am after the elusive MSTD_EU_SK_P6230 firmware file, the link posted to it on wednesday doesnt seem to be working now. Does anone have a copy that they can send to me please?
My links only 24h Activ
This is what I see when I open the link.
Correct, more then 24h Over
https://mega.nz/file/xn8WlQCK#vEyrHUD997FiQJmQ8jUu9a-YOxSZS1oA5TCSBHcL4SA
Super star!! thank you for this.
Please send me teh Bolero MIB1 0490 firmware for part number 5E0919606.
@pab567 , kan du sende et link til nyeste software til min radio?
Device part number: 5E0035020B
Hardware: H42
Software: 0292
Navigation database: V03959800MBO078 ECE 2014 "Gracenote" database: = 8 CRC = 923 / Revision 5203 (build 1) of the eCDDB database[EU][Little Endian]. Media codec: N/A
5E0919606 is display part number for Columbus, not Bolero. Pls post part number and current SW version of your infotainment unit.
@maxgabi @StefGaarddk I sent you download link for MHIG_EU_SK_K1552 in PM
I have a 2015 vrs octavia... I am told I can't upgrade head unit because of canton amplifier... I don't have smart link..... Is there a way of getting android auto
You can Upgrade, you need Dataset from mib1 and have To Upload this Dataset in the mib2
I ve download the file, extract and copy sd card but stil dosent work.
I have found a mib2 on ebay been told its plug and play... I have canton is the only problemScreenshot_20260221_105615_com.ebay.mobile.jpg
Screenshot_20260221_105611_com.ebay.mobile.jpgScreenshot_20260221_105615_com.ebay.mobile.jpg
Just now, Richard80945 said:
Can pabz advise
You have Canton?
Then it cannot be plug and play as you also need to change the Canton amplifier when you switch from MIB1 to MIB2. Oh and the coding needs to be corrected to match your vehicle, and the USB socket needs to be changed also.
IT IS Possible mib2 with mib1 Canton Dataset
Previously it's always been said that a MIB1 Canton amplifier cannot be used with MIB2, so it's good to know there is a way round - provided you have the tools to install the MIB1 Canton dataset.
  • 3 months later...
Sorry for resurrecting;
@pab567 If you have a minute spare could you let me know if there's an update available for my Bolero:
Device part number: 5E0035842A
Hardware: 041
Software: 0435
Installed SW Train Version: MSTD_EU_SK_P3420
Software version: 1 3.41.19_H1 5.10.1 38_STDPlus_EU
Link to download MSTD_EU_SK_P6230 (0490) sent in PM
Hi im, new here and am also looking for Bolero multimedia update.
@pab567 i was wandering if you have an update for my multimedia.
Specs:
Installed SW Train Version: MSTD_EU_SK_P2313
Installed SW MU Version: 0132
Part Number: 5E0035812
Software version: 12.29.1_H11.32.45_STD_EU
Thank you in advance
Edited by Trk505
I do not recommend to try any update for 5E0035812 as it quite often gets bricked. What do you expect from the update?
Im trying to activate the Bluetooth. The car was originally shipped without it. And even tho I've managed to make it show the Bluetooth option as a source with coding. The chip isn't turning on.
