New SE L boot rattle
On 06/03/2021 at 09:59, 1stkaroc said:
 Although I don’t think you can tow a DSG car
I think you can see see page 176 of the Manual.
tom
  • 3 years later...
  • Replies 79
  • Views 25k
  • Making heavy weather of this guys........just pull the cover off with your fingers from the top and adjust as required......
  • Berisford
    Berisford
    Your welcome.........glad my post is still fixing boot rattles.
  • Ok. Do do a follow up post once the mechanic does the adjustments, as it will be helpful for others to know if this could be a fix for their boot rattles. Seems rattles do crop up from time to time!
I had the exact same issue with my nearly new Karoq Sportline 2025 and I couldn't find the issue. I removed everything from the car, checked the bottom, nothing. Then I found this post (thanks a lot!!) and changed the bump stops from 3 to 5 (so 2 more out), easy to do and the issue is gone. So happy :)
Had exactly the same rattle in my boot on my 2024 1.5 SE L Karoq, stripped the rear end and could not find anything. Then found this post moved the bump stops out 2 sections and fixed no more rattles !
Had exactly the same issue. THANKS to all those on here, especially the genius who provided the solution. Intermittent knocking noise has now disappeared. Was ready to trade in my 2023 plate!!
