Cleaning corroded rear discs using EPB! Oof!
Having suffered from the made of cheeserear discs I found reversing at 15mph down a gentle slope and then braking hard 2 or 3 times worked as well.   Rear discs gubbed at 26k miles and33 months.  Though this was a car that lives outside on Scottish roads that are salted for several months a year.
Thanks xman for your pioneering spirit :thumbup:
My VRS's rear discs were pitted and noisy and got replaced at under 20k miles and under two years.  It had an analogue handbrake so was easy to keep clean and shiny afterwards.  The GTI has an EPB so I was wondering how to go about it.  After a few stationary weeks recently there was a noticeable donk donk donk from the rear that took a couple of miles to clear.  Like irc's reversing suggestion too.
Gaz
Edited by Gaz_
Correcting the poxy autocorrect
does anyone know what type of brake discs skoda use, and is there better makes that can be swapped to solve this obvious problem.
I’m going to say EBC as that’s what’ll happen my rears in a few months, when it gets warmer outside.
any links to the EBC ones thanks bud.
Sorry I’m terrible at links and anything computer related. Something like EBC brake shop or EBC brakes direct would be my usual spot for ordering what I need. I think EBC themselves added links in a thread in the maintenance section of this forum.
ok no probs, i am still looking for a car when i get one i will look at changing those back discs .
EBC brakes are **** imho.
Edited by Bigeater
Not a direct answer, but worth being aware of (and a Brisky sponsor):
Gaz
Gaz
Stop sharing that!! I need a set of yellow stuff for the front of mine. 😂
I’ve found driving in eco with DSG to clean the rears up lovely, it still looks like my pads are like an 1” too small as the outer edge of disc looks untouched (but weird) but at least the middle has come up better at 36k or so
Edited by Danoid
Is that because you find yourself braking more? On the rare occasions I use eco I tend to use the paddles to pop it back into gear if coasting too quickly.
Exactly that, when I’m eco is disengages then tend to coast a lot more, so I can apply the brakes for longer.
At first I hated eco as the driving experience is more clunky feeling with lag etc but i’ve got use to it, I keep meaning to put it back into normal driving mode but keep forgetting
Following comments here and with some further testing, I can confirm what others have suggested as an alternative. Hard braking whilst reversing at a fair speed applies the rear brakes in priority to the front, so also useful for cleaning up the rear discs. Makes sense that leading brakes are used depending on direction of travel.
Obviously this method is a going to be a bit gentler than using EPB (forwards) at speed, depending on how fast you reverse and how hard you brake. Obviously its more dangerous to reverse at speed especially on a public toad but less dramatic without the mysterious fart from ABS or whatever.
I would recommend some cleaning is done regularly as once the disc corrosion gets to certain level, it may be difficult to restore them to an acceptable condition.
A little often rather than a lot all at once.
