Skoda Columbus retrofitted in Octavia 2 pre-fl - Maxidot issue
Hi there,
I installed a Columbus head unit into my Octavia mk2 pre-Fl VRS 2007, with Maxidot display. Everything wors perfectly, expect three things:
- Maxidot doesn't show any Navigation informations (arrows, directions, street names, etc.). The "Navigation" menu is active and I can select it from the menu, but it shows only: "RNS TRINAX". The "Audio" menu works well, itt shows the title of the tracks, FM stations, etc.
- I cannot exit from "Audio" and "Navigation" menu with the wiper stalk's buttons. (I read before, it is definitely SW problem)
- The litte compass in the top lef corner of the screen doesn't appear, but the clock moved form top center to the top right position
I coded in VCDS:
- 37 Navigation added into CAN Gateway's installation list
- 56 Radio is still ticked in CAN Gateway's installation list
- 37 Navigation was coded in "Coding" menu in VCDS as BAP protocol disabled
- No DTCs
- No battery drain
Some infos about the installed modules:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 G HW: 56D 035 682
Component: RNS-MID H50 5238
Revision: AB001001 Serial number: VWZ6Z7L6066087
Coding: 00000400000100000006
Shop #: WSC 12345 123 12345
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 1Z0 035 729 B HW: 1Z0 035 729 B
Component: FSE_2P7x H31 0050
Revision: 00000001 Serial number: 00000005010023
Coding: 0000311
Shop #: WSC 73430 790 00000
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 270907F2002371
Coding: E9817F0E4006021302
I attach few "screenshots" about my problem.
Can anybody help me to solve this issue?
Thanks,
Peter from Hungary :)
IMG_5384.jpg.ff9b49991c1138b750d1f4a6bca178f2.jpgIMG_5385.jpg.21449682e96c6e30254d69efed9f8bb7.jpgIMG_5389.jpg.b8e5542599a47c8fcbfc9be7498947a1.jpgIMG_5390.jpg.80f57941c3733a54e44a1593d6857472.jpg
The issue with not being to exit the menus is a software bug on the stereo. There is a software fix somewhere for the Octavia that I found.
Have you checked the coding in the instruments and in the radio? There are some options in there I believe. In the radio coding I believe there are some options regarding display type etc.
Thanks for your reply. Yes, I know. But not this issue is my biggest problem now.
I checked the radio and a navigation (same devices, but on different address). I switched the BAP protocol off. (first time I switched the BAP on, but the audio and navigation menu disappeared with this setting) So it uses DDP protocol.
Can I code something in the instrument cluster as well?
Update:
- I tried to "re"-update the 5230 FW (by josi) version. I tired 3 times, but always finished with error after 11% on Gateway update process: VuC library error - Can gateway 202 error
- I tried to downgrade to 4120 FW factory version, but I got the same error messagge
- Finally "fixed" with the recovery disk (by josi)
- So it uses the 4120 FW now, but the navigation menu still showing "RNS TRINAX" only
Udpate:
Finally it turned out, my Columbus is HW faulty. I tried with an other Columbus in my car, and it worked.
On 18/05/2021 at 17:36, katzenberger said:
Update:
VUC library error is an indication of a failed unit. Josi recovery disc won't fix this.
Thanks for the info. I sent back the unit to the seller. I hope it will be refunded...
I bought a "new" one form an other seller, and it works well. :)
