Headlight washer not working
OBDeleven vehicle history log
Date: 2021-07-01 16:58:57
    VIN: TMBAH7NP2H7009796
    Car: nvm20
    Year: 2017
    Body type: Saloon
    Engine: CRLB  kW ( hp) l
    Mileage: 368688 km
09 Central Electrics
        System description: BCM MQBAB M+
        Software number: 5Q0937084CF
        Software version: 0236
        Hardware number: 5Q0937084CF
        Hardware version: H34
        Serial number: 02001614101021
        Faults:
                B126215 - Headlamp washer system activation
            Open circuit/short circuit to B+
                static
                    Priority - 4
                Malfunction frequency counter - 2
                Unlearning counter - 70
                km-Mileage - 368682 km
                Terminal 15 status - On
                Terminal 50 status - Off
                Voltage - 12.4 V
                Outside air temperature - 15.0 °C
                Status Bremslichtschalter (HW) - Off
                Status Bremslichtschalter (CAN) - Off
                Off - not activated
                Parking light - not activated
                Automatic high beam assist - operated
                Low beam - not activated
                Parking light left - not activated
                Parking light right - not activated
                Letzte Weckursache/ Werte [00;2E] - keine Störschutzursache
                CAN-Bus aktiv - On
                date - 2021-07-01 15:27:43
Does anybody know what might be wrong
Might be a silly question but did you try them with the lights turned on?
Yes have done but won’t pop out no motor noise
I went to the dealer he refused to tell me what might be wrong he said who needs them just waste washer fluid
that's telling you there is a short on the ignition live circuit it also says its only happened twice
How can I find and fix it
check the basics first fuses and  continuity of wires  but it sounds like and i don't mean to be nasty but you may need to let some one look at it that is qualified
All fuses are good
Didn't u say u recently had one of ur headlights replaced?
Whoever did that has likely done something to the wiring/connector for the bumper electrics.
An "Open Circuit" usually means it's not connected or unplugged, or the wire is cut/damaged.
The problem was there when I bought the car a year ago with no collision on it the jets can manually move out no motor noise or anything have taken the little green relay and swapped did nothing allthough a pin in the relay seems loose do u have the wiring diagram by any chance I know an electrician that’s good in far electrics if u have the diagram that would be awesome
Don't the headlight washers pop up using water pressure, not a motor?
Correct :)
The wires to the water pump may be damaged or disconnected. That's certainly where I'd start checking.
I know this might sound daft, but how much washer fluid is in the tank?  Most cars i've seen with headlight washers, they'll quit working when the fluid level gets to 1/3 or 1/4 tank left so you still have fluid to scoosh the windscreen with.
@langers2khow can I gain access to it
To erwin?
Sign up, pay some money (€7 + tax for an hour), enter your VIN and download everything you can :)
It should be possible to get all the workshop and wiring diagrams for your car in that time with a decent internet connection.
There was one plug disconnected from previous owner attached it and it works
  • 3 months later...
@Andrea11 which plug was disconnected. I'm having the same trouble code.
Might be an idea to PM Andrea11, as he may not be watching this thread and a PM will send him an email notification…
