Skoda Members' opinion is required
On 23/07/2021 at 20:31, Thefeliciahacker said:
Get a weber downdraft and you wiil be all set.
On a serious note there many more knowledgeable people in here for carb aspects
it doesn't worth it as my car reach 125 to 130 km/h and maximum speed according to resources said 145 km/h if lucky reach 160 km/h
i want to make my pierburg 2e3 work well and every thing will be fine
  • Replies 91
  • Views 6.7k
  • I respect that. Good description. Now we have a better image of the entire situation. The best thing you did was changing the gearbox. In order to get full engine power/peak engine performance/
  • Everything sounds normal. Temperature is normal. 90°C. It is a problem of fuel starvation on 2nd stage of the carburetor. 3.1 What do you mean by "it worked" ? 3.2 Not sure i
  • You'll find at the link below the service manual for the carburetor. https://disk.yandex.com/i/eTm3c2PLBnWgag You'll have the answer to all your questions in there. It is a very good read.
1 hour ago, RicardoM said:
@captain_crunch
I have just realized that you didn't tell us HOW the low power fault started to occur. The history.
  1. Was the low power issue always present since you have the car?
  2. Was it a sudden drop of power? Any guess what other thing happened prior this issue?
  3. Was it a slow decay of power?
oh i well tell
 yes as the car have low maintince for a while as my parents only was driving it from 1997 to 2014 after that  i begin to drive the  car since 2015  of course didnt know much about car mechanics i face many problems and have not much experince as now
1- lack of power ((1-faulty stage 2 + carbruter was very dirty)  2-wrong valve clerance 3- engine oil need replaced 4- gearbox 10s was broken i dont until now how this happen causing very huge leak in gearbox oil 5- spark plugs need replaced 6- fuel filter need replaced also air filter need replaced
2- have problems  with barke system (1-brake master cylinder  2- all brake pads need replaced 3- brake discs need replaced 4- brake fluid need replaced )
3- have problems with coolant as it was using tap water not coolant fluid this cause a rusty nightmare in coolant system (1- faulty water pump 2- rusty hoses and pipes 3- rusty radiator )
at all i solved this problems
1-  1- replaced 2nd stage diphram + clean carbruter 2- make new calibration valve clerance 3- make engine flush and replaced new engine oil 4- replaced gearbox 10s with 14sk 5- replaced spark plugs 6- replaced fuel filter and air filter
2- 1- replaced brake master cylinder 2- replaced all brake pads 3- replaced front brake discs 4- replaced brake fluid)
3- 1- replaced water pump 2- replaced rusty hoses and pipes  3- replaced rusty radiator also flushed the coolant system and put coolant fluid but still there rust i think it will be always forever at all i am i lucky and thx god the orginal headgasket still working well :)
not much the most problem in top speed also i have belief the only part that need to be calibrated is carbruter as i say before enrichment valve not working also carbruter need a good clean
sorry for long description but this felicia have a lots of memories with me since 1997 i was 5 years old and i consider it one of my family not just a car :inlove:
14 - yes enrichment valve consider be defictve its not working
16- i think float is working well no fuel flood in carbruter or hard starting the engine
18 -throttle gas open completely
19 - i tested stage 2 diaphram by sucking it worked well
20 - what jets meant not as specified is it mixture screw or (1st stage get and 2nd stage)
i have discovered  that distrbutor advanced not working also its stuck its the orginal distributor can the vaccum advanced affect top speed or just performance ?
at all i have new distributor
In order to get full engine power/peak engine performance/good acceleration, the following prerequisites are mandatory:
  • good fuel delivery
  • good engine breathing (both inlet and exhaust)
  • good ignition and ignition timing
  • good valve timing
  • good compression
Now, to answer your question, a stuck distributor affects directly the ignition timing, hence the combustion, hence top speed and acceleration.
  • good valve timing
  • good compression
i want to install new distrbutor by myself but i want steps to not face any problems
Installation is the exact reverse of the distributor removal.
Any tips, I mean other than "even professional mechanics don't always get a new distributor on the right tooth of the drive cam first time"? :)
ok
Threads and posts need to be in English, bar one specific regional sub-forum.
As such I have hidden the posts that are not in English.
You are of course welcome to repost in English and keeping it in English.
7 hours ago, Agalalh said:
صباح الفل
لقيت تروستات كوعة 80  فين انا محتاج منها
@Agalalh
https://www.briskoda.net/forums/guidelines/
All posts should be made in English. The use of other languages, or "txt speak" is not permitted and will lead to posts being removed.
You wrongly assume that the distributor for Felicia 1.3 with carburetor is one part that goes to the camshaft. In fact it has 2 parts. A holder, that is removed only when the timing cover is removed, and the distributor per se.
That is why removing the distributor means in fact removing only the top part of it hold in place by a clamp with a screw.
That is an unusual design, with obvious advantages, at least as long as the distributor shaft bearings in the holder never wear.
Every distributor has bearings. This one too. There are three bronze bearings that have all lubrication points. The holder has one long bearing lubricated.
ok
i want to flush my coolant system from rust any ideas ?
some opinions that i can use citric acid in coolant system but not sure  it can cause damage
2 hours ago, captain_crunch said:
citric acid
dont use any acid,
Step 1 remove upper rad hose from engine side,
Step 2 remove thermostat housing
Step 3 get garden hose and stick it in there open it and let the water run
Step 4 go back and forth one time stick it on the engine the other on the rad hose
Step 5 to clean the block remove lower rad hose and flush it from top to bottom
Step 6 to clean rad flush it from bottom to top
Step 7 close the cooling system add distilled water and drive the car for a day or two,
Step 8 drain it
Step 9 repeat step 7+8 until water becomes clear.
Step 10 drain distilled water and fill with pre-mixed antifreeze (70% 30%)
@captain_crunch
Any progress on the main subject of your topic? You know, power loss and stuff... carburetor and distributor problems.
18 minutes ago, RicardoM said:
@captain_crunch
not yet i will begin soon
21 hours ago, Thefeliciahacker said:
dont use any acid,
Step 8 drain it
can you pickup some pictures of hoses to be more clear
1st upper rad hose
2nd lower rad hose
Inkedbakov-nad-jizerou-czech-republic-13th-sep-2017-skoda-favorit-admirer-K720YE_LI.jpg
2 hours ago, Thefeliciahacker said:
1st upper rad hose
2nd lower rad hose
step 3 you mean i stick garden hose  in thermostat housing place in engine itself ?
step 4 dont get it clear ?
step 1 to 6 while engine is off and cold ?
Edited by captain_crunch
Yes after you remove the housing let water flow from the head downwards
So you have removed the thermostat housing and you have the upper rad hose free. One time feed water into the head so water will flow out of the upper rad hose the other time feed water to the upper rad hose so water flows out of the head
All steps cold and off only step 8 is more effective with a slightly warm engine right after turning it off (before all the solids sink)
Edited by Thefeliciahacker
i made modfication to be able to put 60m thermostat on felicia half of the hermostat housing from favorit and other from felicia as its recommended by @RicardoM but i wonder if this sequence below is right the black lines i will but thermal silicon
number 3 will be silicone with the gasket and second part
Black silicon is recommended only if you don't have a normal gasket.
