How To: Heated Windscreen Retrofit
ApertureS
  • 5 months later...
Excellent tutorial well done
Thanks to your guide I managed to fit the screen to my VW Touran. Being part of the VAG group the installation is very similar.
The only differences for VW to your instructions are as follows:
1. Climatronic control panel does not need to be replaced. VW don't have a dedicated physical button sadly and only the infotainment screen can turn it on/off. Simply coding as per your instructions works fine.
2.
The wiring diagram for VW is simpler. No fuse in the interior car fuse box. There are 3 fuses to be installed in the engine fuse box only with two relays. The BCM wire at T46 still remains the same.
Coding and everything else remains identical. So thanks for helping a VW user out here too!
PS- I've also retrofitted the ADAS camera. It's the same for Skoda so if you need any help let me know.
All the best
  • Thanks 1
2.
All the best
Youre very welcome, glad it came in handy.
Ther superb is i believe the only model to have a single relay and a back and forward trigger for it.... everything else including the octavia uses 2 relays under the bonnet and a single wire from inside the car, not 2. That being said, for simplicity you could very easily just take a feed from the front fuse box instead of the interior fuse box.
ADAS was retrofitted quite a while ago in mine but thanks for the offer.
Great stuff!
How do you find the heated screen? Worth the money? Probably cost me about £175 to fit including windscreen excess. I've yet to test it as I've had no frosty mornings!
Does it clear quickly?
I've also changed the adaptation in the module for "Windscreen heating on MAX defrost". In theory when you press the MAX defrost button the windscreen heater is supposed to come on too. Have you seen similar?
The only indication I have at the moment my work is working is there is a slight rev drop when pressing the button. I don't hear any relay click but I guess the engine drowns that out.
Let me know if you don't mind. Thanks again
16 minutes ago, Matt0020190 said:
Great stuff!
A fully frosted and solid with ice windscreen will be wipable with the wiper blades in about 3-5 minutes roughly. Also stops any condensation build up on the inside. I get in the car, switch the heated screen, seats and mirrors on and by the time ive set the nav and picked a song its almost ready to go. Would love the heated steering wheel next though.
  • Administrators
I use the heated steering wheel far more than I should. Poor circulation.
I don’t mind scraping the windscreen, it is heated but I forget more than I remember.
the heated wheel though, just perfect  for cold or slight wet days :)
so get it done ;) not that I know how.
Cheers for that sounds good
I've done the steering wheel also. Wasn't too hard at all. Main challenge was changing my clockspring to support the heated wheel. Other than that the rest was straightforward.
That's cool too as all I do is tap the heated seat button and the wheel comes on too. Even better if the outside temperature is less than 3 degrees, it turns on automatically also
So you scammed your insurers?
  • Confused 1
Do you mean that the excess which you paid was for the difference in price between the replacement cost of your cracked non heated screen and a heated one?
Thank you for your excellect guide! I am potentially looking at getting this done once I find a windshield I can take off a breakers yard. Maybe for my wifes Golf too as it tends to have alot of condensation!
Both you and Matt0020190 mentioned coding for other units, but nothing for the radio? Does the heated windshield button appear in the air conditioning settings once you retrofit it with no extra coding?
Thank you again!
Thank you again!
Exactly yes, the only 2 modules effected are the HVAC and Central Electronics. The 5F radio will display the button automatically.
6 hours ago, Agustnr said:
Sorry for bumping this and asking a stupid question, but should you ideally do the wiring prior to the windscreen fitting or it doesn't matter?
Either way round is fine. Just isolate any open connectors from the elements
1 hour ago, M17HSN said:
Hi ApertureS would you know the items needed for a passat b8 and the costs involved?
They won’t be too far different, if you wanted to let me know your registration I can work it out.
When you say costs, did you mean you want the price for it fitted?
hi ApertureS
I'm not that familiar with mechanics\electrics etc so it's either sourcing someone in Lancashire to fit everything or finding someone who can fit it.  I would be grateful if you can fit it then give me a price, if not then if you can give me a price for the components.  The reg number MD68TYV
hi ApertureS
For your car:
3G0845011ACNVB - heated glass, without lane assist camera - retails roughly £1000
3G0845011BBNVB - heated glass with lane assist camera prep - retails roughly £900
 (Weird how the lane prep glass is cheaper)
This is the prices for genuine glass, of course aftermarket glass is also a cheaper option and you have the choice of with/without lane assist prep which can also be retrofitted at the same time if not already fitted.
If you wanted to discuss it being fitted any further please drop me a message on my signature below or private message me :) if you wanted to consider doing it yourself please continue to ask questions here as it can assist others too
thanks
  • 4 months later...
Hey! Anyone else had issues with changing the climate control panel?
My initial version was a 3V0907044DA (manufactured 2018) and managed to get my hands on an older 3V0907044AJ from a 2015. The panels look a little different but otherwise seem to be a good match (the new one is a matt black instead of the piano gloss but after another week of wiping fingerprints from it I was happy for the change!).
Anyway managed to get it installed and coded with VCDS with the original coding but now it won't show up on the infotainment screen - just shows off and won't pop up when pressing the "settings" button.
Anyone else had this issue? Any ideas on a fix?
Any fault codes?
Can you connect to it via diagnostic?
I think your issue is you’ve fitted a much older control unit and it’s not compatible, but would need to see the fault codes first to know.
The one you have fitted won’t have functionality for a bypass valve compressor and only a magnetic clutch so coding it to have one would do nothing. (Unless it’s got newer software on it)
2 hours ago, ApertureS said:
Any fault codes?
Cheers for the help @ApertureS
I did wonder if it might be a bit old.
I do have some codes show up in VCDS mainly relating to the rear vents that don't show up with the original unit:
Chassis Type: NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 36 42 44 4B 52 5F 6C
          75 BB BC
VIN: TMBBJ7NP1J7570828   Mileage: 102997km-63999miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
75-Telematics -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-DFHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 TM    HW: 04L 907 309 P
   Component: R4 2.0l TDI   X25 6312
   Revision: B4X25---    CVN: 6369B71DB866C2AD00000000
   Coding: 01250412036405083000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026TM 005001
   ROD: EV_ECM20TDI01104L906026TM_SK48.rod
   VCID: 0849976C22B4A17A673-805C
   VINID: 91D4926877A005A1C51C020220FCC39D2A
1 Fault Found:
28992 - No Communications with NOX Sensor 2
          U029E 00 [00100111] - -
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 102997 km
                    Date: 2024.04.29
                    Time: 08:28:35
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 85  C
                    Intake air temperature: 78  C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.220 V
                    Unlearning counter according OBD: 40
                    Limitation: accelerator pedal: 0.0 Nm
                    CAN status - engine control module-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    CAN status - transmission control module-Bits 0-7: 0
                    CAN status - brake control module 1-Bits 0-7: 0
                    CAN status - brake control module 2-Bits 0-7: 0
                    selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels:. 0BH-927-711.clb
   Part No SW: 0GC 300 042 H    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07    CVN: FC60F4E0
   Coding: 0014
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 2B0308E0D382AA62AA1-807E
   No subsystems:
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 DA    HW: 5Q0 614 517 AH
   Component: ESC           H62 0753
   Revision: 00000000    Serial number: 60338000000687
   Coding: 1D07929C34270B6C477F060240CB49B8492CD0E2600292753861F078C209420B00000012121212B835351919323200
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 73B3D0804B32B2A2221-8026
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0468930754 Dataset Number: V03935254SK 0001
   Coding: 032C0C070F
   Shop #: WSC 33361 790 00156
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E2531B430F02FCA1DF-806A
   Rear lid opener control module:
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 AJ    HW: 3V0 907 044 AJ
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00034578
   Coding: 11110104002110011005004C0010102A
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 7CA1FBBC666CFDDA73B-8028
2 Faults Found:
197634 - Temperature Sensor for Rear Vent
          B1089 15 [00001001] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 102997 km
                    Date: 2024.04.29
                    Time: 08:28:33
                    Outside temperature: 15.5  C
                    Voltage terminal 30: 12.1 V
328455 - Position Sensor for Rear Temperature Flap Motor
          B1096 15 [00001001] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 102997 km
                    Date: 2024.04.29
                    Time: 08:28:33
                    Inside temperature: 12.5  C
                    Rear temperature flap: actual value: 0.0 %
                    Rear temperature flap: actual value: 512
                    Rear temperature flap: specified value: 414
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001803300303 Dataset Number: V03935274XW 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 094F926839BED87278D-805C
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 150304  032 0121
   Serial number: 00000001503020600254
   Coding: 165DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Component: RLHS  047 0105
   Serial number: S5Y18M02D06H07M57S53
   Coding: 00084D
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1734116T7
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0314
   Serial number: 00002856223972902210
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417320181 Dataset Number: V03935278BG 0001
   Coding: 0431151851
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000_VW41.rod
   VCID: 51FF7A08916EA0B2F0D-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Dataset Number: V03935249LS 0001
   Coding: 3200678151FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35372E9805C6EC92CC5-8060
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    005 0336
   Serial number: 003VVR3V9FP3 Dataset Number: V03935255BE 0001
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002158
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 074B94502FAAAE026E9-8052
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 003 001 18
   Component: SideSensor_Df  001 0887
   Serial number: 357000000006E8D42B2W
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 003 001 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000001E8D42B2S
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 403 101 18
   Component: SideSensor_Dr  000 6149
   Serial number: 3510001BB28D6142761$
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 402 901 18
   Component: SideSensor_Pr  000 6149
   Serial number: 3520001AD28A2CC366DM
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 101 18
   Component: FrontSensor_D  000 6149
   Serial number: 3550001A328C22E512E3
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 569 C    HW: 5Q0 953 569 C
   Component: Lenks.Modul   100 0265
   Revision: --------    Serial number: 20230505500383
   Coding: 6014
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001009
   ROD: EV_SMLSVALEOMQBLRH.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3VD 920 790     HW: 3VD 920 790
   Component: KOMBI         505 1710
   Coding: 25A5011A2F80A600018863011001000800000000
   ASAM Dataset: EV_DashBoardVDDMQBA0 001031
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 L    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5323
   Serial number: 29011810520042 Dataset Number: V03935276GC 0001
   Coding: 030100045F087300EB00025A1C0F00010001070000000000000000000000
   Shop #: WSC 33361 790 00160
   GVL: 01563C0000000600401C80008002C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 382927AC12D411FAD73-806C
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 H    HW: 3V0 919 719 H
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000A2948240919
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 1108436404
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000007836006
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_SK48.rod
   VCID: 333310800BB2F2A2E21-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RB426277 Dataset Number: V03935281EC 0001
   Coding: 0014000000000500018280808080000000008181000000D400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3D2736B83DF634D2045-8068
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 E    HW: 5Q4 959 593 B
   Component: TSG FS        011 0032
   Serial number: 0000302254915  Dataset Number: V03935256LT 0001
   Coding: 001D8020DE01040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 47CB54506F2A6E02AE9-8012
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Dataset Number: V03935273KF 0001
   Coding: 81170000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 27011810524395 Dataset Number: V03935274LG 0001
   Coding: 000000020100066E00003F01000000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 001010
   ROD: EV_MultiModulContiVW48X_001.rod
   VCID: 72BDD5843428BBAA297-8026
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo links  H01 0006
   Coding: 000000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329
   Component: Leimo rechts  H01 0006
   Coding: 000000
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 E    HW: 5Q4 959 592 B
   Component: TSG BFS       011 0032
   Serial number: 0000301991938  Dataset Number: V03935256LV 0001
   Coding: 001D0220DE01040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 46D559546820770A55F-8012
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 565 035 021 B    HW: 565 035 021
   Component: MU-H-LND-EU   H54 1240
   Serial number: A853A0JS025626 Dataset Number: V03935271AF 0001
   Coding: 03840101FF00000041111201008808102F0100E601200400DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 0D47A6784DD6C452545-8058
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHV0314019
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 810 C    HW: -----------
   Component: ECE 2022  --- 0195
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1017
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H18 0231
   Dataset Number: V03935257YE 0001
   Coding: 047300010600041F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392F22A829DE08F228D-806C
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [RearView system not calibrated]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 58
                    Mileage: 102997 km
                    Date: 2024.04.29
                    Time: 08:28:33
                    passive
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0718
   Revision: --------    Dataset Number: V03935277FY 0001
   Coding: 03840101EA421A0D3B1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW37.rod
   VCID: 3C213BBC26EC3DDA33B-8068
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       012 0032
   Serial number: 0000302984496  Dataset Number: V03935256MF 0001
   Coding: 001880208001040000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   ROD: EV_DCURearDriveMAXCONT.rod
   VCID: 49CF5268793E9872B8D-801C
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      012 0032
   Serial number: 0000302153229  Dataset Number: V03935256ML 0001
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
   ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.2V)-----------
I've spotted another version on ebay at the moment - 3V0 907 044 EG which is from a 2017 Superb. It's still a year earlier though and shows an earlier software version (i assume thats what the SW number is) of SW4101. Mine was a 2018 with SW4402. Don't suppose you know if thats likely to work?
