Hello skoda octavi 4 Coding List and Adaption
Hello skoda octavi 4 coding list  do you have some coding info ?  rear light drl, stagging or VRS theme virtual cockpit ? and more ? for sharing please? a i have obd11 and sfd unlock
  • Replies 100
  • Views 42.3k
  • OCTAVIA IV CODING tested working coding obdeleven To verify 3 steps  unlock SFD, 1 is registration add name ... which was normal, then parking  brake must be on, hood open, ignition on...  SFD
  • I have OBDeleven Pro and have been able to change Lane Assist to "Last setting" I did this manually through the long coding so now one of the annoying pre-flight checks is eliminated ! Driver as
  • "The same as for permanently disabling start/stop system"   i m  really looking for that !
so far no app can be coded. still nothing. hope will be soon.
i see o4 2021 stagging, disable seat belt, rear light drl,  sport displej,. rs theme :)  coding normál :)
Is it just me, or is anyone else suspicious when a relatively new member suddenly finds a solution that is a website based in another country and at first glance seems to offer something for nothing.
Almost feels to me they are involved with the promotion of it, or being paid to get sales.    But maybe I am just wary.
 i dont propage other website :) i write answer for coding how to coding :) my dad have o4 and i need enable rear light :) and stagging
i have obd 11 but im not able to code anything of it. its not possible , or something went wrong. i couldn code even  fan level display ...
John am with you , location set as Europe , no one on here does that. BOGUS!!
57 minutes ago, bolix said:
Mám obd 11, ale nedokážem z toho nič kódovať. nie je to možné, alebo sa niečo pokazilo. Nevedel som nakódovať ani zobrazenie úrovne ventilátora...
thx for answer
i have coding working for
Rear DRL Lights
With this modification when you have the DRLs on, the outer taillights will also light.
1 - Module 09 - Electronic control unit
2 - Adaptation
3 – Daytime running light
4 - Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht: - (Change value to On)
CONFIRMED WORKING
My OBD 11 is now has a list of App adjustments, power & torque display, mirror puddle lights etc. I've no means to verify that they work as I have a MK3.5 VRS245
Sorry, should have said, they are for the MK4 Octavia
I have had a mail also of the new sfd unlock of obdeleven which is awsome. Have vcds and obdeleven and i really like the portability of obdeleven and now with the unlock it's next level now.
True, i SFD unlocked today through OBD11 while activating the alarm chirp with fob lock.
however the remaining apps are all giving me “check ignition and try again” even when ignition , hood and parking brakes are all on.
It's good to be suspicious these days. :) But Obdeleven really did announce they now support SFD unlocking. It was discussed also in other groups.
Edited by TheUltraRunner
Probably bugs that needs to be ironed out. I cannot test myself as my car is still on a piece of paper and not build yet 😕
i tried all of that with no successs. i receiving messages on obd like.... something went wrong... try again .
Ok i found out that we need to verify 3 steps in registration which was normal, then brake must be on, hood open, ignition on...  SFD unlock each module in aplication , not only 1 , u need to unlock all...after that u ll be able to do some coding. So i finally  managed to turn of seatbealt warning, drl etc, ok did you you findout that u can watch even you tube videos even with handy off, without youtube premium acc or watching tv throug mirror link but mobi needs to be on. And all that while driving a car
hello bolix share coding for disable seatbelt and more :) thx
change Octavia IV Virtual Cockpit Theme
17 - Adaptations - view activation - click to activate the ones are off....and enjoy
Are there any new ones?
yes activate all viev activation :)
Hi! which modules or codes you used for this screen mirroring or youtube possibility?
Cant unlock. Still sfd protected.
How is the picture than made of Bolix? I see a screen mirroring right?
