the truth about electric cars
1 minute ago, Graham Butcher said:
I think it was also mentioned at the time of introduction as a means of noise reduction for those living alongside the motorway.
EVs are quite apart from tge standard tyre rumble and aero noise as motor almost silent though it does sing Jean Michelle Jarre when sub 20 mph.
We are still waiting for those ENSO tyres which can give 10% more range and presumably are quieter as well.
Edited by lol-lol
  • Replies 13.1k
  • Views 862.9k
  • Their efficiency at any speed is more than double that of an internal combustion engined vehicle.   The improvements in aerodynamic efficiency have pretty much all been made in recent decade
  • So surely you should be welcoming Graham's interrogation of the data and news items?   There are clearly many false statements being made on both sides of the fence...   so a balanced discus
  • Latest I've seen about cause of FH fire   https://www.electrive.com/2023/08/14/it-wasnt-an-ev-that-caused-the-fremantle-highway-to-catch-fire/
At motorway speed the drive by noise is dominated by tyre noise, so EV or ice the noise levels are similar unfortunately, and can, in fact, be higher with EVs due to the harder compounds and structure of the tyre needed for their (usually) extra weight.
Edited by skomaz
3 hours ago, lol-lol said:
Probably right but it does annoy me in places like the motorway near Birmingham and Sheffield when it says reduced speed limits due to pollution when it is the ICE vehicles causing the pollution and not EVs.
I think the main developments will be in more EV trucks being on the market and its effects. EV trucks look capable of towing two containers / trailers rather than just the one that ICE trucks can also EV trucks are going to want to pass ICE trucks on inclines due to their superior climbing ability and this could cause a few issues.
What actually makes you think that electric trucks will out perform ICE ones in terms of towing etc? That certainly has not been demonstrated by the electric vans, or indeed cars towing caravans has it? Manuefacturers hyped up claims are never ever matched in reality and nowhere is that more evident than in the EV world.
Exactly, but those speed limits where put in place before EVs were as common as they are now.
The stats support it, more power and more torque.
My company Ceva was seeing several minutes quicker runs by the EV trucks running up from the Spanish ports that connect with Morocco up to Madrid and onwards.
Ceva use Winrose EV truck for such runs.
Edited by lol-lol
I think the EV weight much more thing has become an entrenched myth. Germanic EVs, Audi, BMW, Mercedes, SEAT, Skoda and VW tend to be heavier than the average EVs and many have fallen foul of the Paris 2 tonnes triple parking charge. I am surprised there was not more protest by the 3 German HQ based companies as it seemed to single them out. There are some reasonable reasons for Germanic cars being heavier ie there need to be able to do 200-250 kph plus to drive at the perfectly allowable speeds ie bigger motors, battery packs, two speed gearboxes to allow the electric motor to switch to a longer gear and not be limited to 100 mph or less like many EVs. Also on the tyre front, and most are fitted with EV tyres which tend to be quite quiet with less tread when new and alos are oft fitted with acoustic foam to reduce noise as the rest of the vehicle is so quiet Michelin add the foam to further quiet it down. 68 to 70 decibels being the norm. Scenic has e Primacy and % has Conti 6Qs. The Q standing for quiet as again, like the Scenic and other EVs, as they are so quiet in the engine / motor department the tyre manufacture put extra effort in to quietness. Both EV Tyre review reports commend these EV tyres quietness.
https://www.tyrereviews.com/Tyre/Michelin/e.Primacy.htm/Test-Results/
https://www.tyrereviews.com/Tyre/Continental/EcoContact-6.htm
Again, you are not talking about the UK; we just don't have or will have the infrastructure to allow those trucks to become more common here, for sometime to come. I do accept, however, that for some companies and scenarios an EV could be the best solution for them, but for now, it is not a direct one-for-one swap.
Also, tests done by various organisations here in the UK have shown that EV vans just cannot compete on the longer trips or those that are heavily loaded, with their ICE counterparts. Note, I'm not talking about last-mile delivery vans like those used by Royal Mail or other such companies, i.e., Amazon, DPD, etc., all of which may well appear to be fully laden if you look inside them, but the fact is that many of these cardboard boxes contain a smaller blister-packed item, surrounded by bubble wrap or other such protection. I have friends who work in council technical services, etc., and they report that their council trialled some EV vans, of the same type as their existing ICE ones. These EVs were quickly rejected; they could not complete a normal day's work without either running out of power to climb hills because of their load, or they were running out of battery and needed charging to make the return trip at the end of the day.
Others have tested EV cars towing caravans and found them incapable of performing as well when towing and also dramatic reductions in their range compared to ICE versions of the same cars towing the same caravans
Two companies I have been most associated with are Ceva and DPD and Ceva are looking to bring the Windrose trucks to the UK and I presume the frightening increasing in diesel costs and strong desire to go to lower carbon footprint the Ceva UK fleet is predominately running on HVO rather than diesel. Can be a little more than diesel and is erratic pricing. Hope to see the Windrose EV HGVs on the road soon but I am sure they will want to test in cooler weather but Windrose has already done much of this and truck has 800v architecture and charging is very good in the chargers are there which is something Uk government working on with Gridserve and others to hit the 2040 deadline of all trucks being electric..... https://www.gridserve.com/electric-freightway/
https://www.cevalogistics.com/en/news-and-media/newsroom/press-release/ceva-uk-investment-low-emission-fleet
DPD also breaking out from EV delivery vans not just being mainly cities.....
DPD UK is expanding its electric van fleet with 341 new Mercedes-Benz eSprinters, taking the parcel carrier’s total number of electric vehicles to more than 4,000. The first vans are due to enter service in September, with the full batch scheduled to be operational by the end of October. They will be deployed both within the M25 and at locations elsewhere in the UK, ahead of the company’s peak Christmas delivery period. DPD said the new vehicles will allow it to extend the use of larger electric vans beyond the inner-city areas where much of its EV fleet has so far been concentrated. According to the company, its electric vehicles currently operate across more than 7,300 UK postcodes. In 2025, DPD delivered more than 85 million parcels using electric vehicles, including a predominantly diesel-free final-mile operation within London’s North and South Circular roads. Olly Craughan, head of sustainability at DPD UK, said larger panel vans remain central to the company’s final-mile operation.
"The eSprinters can carry the same payload as the equivalent 3.5t diesel while the new battery technology and improved range mean more of our depots can start deploying larger EVs further afield,” he said".
No image preview
DPD pushes electric vans beyond city centres with hundred...
DPD pushes electric vans beyond city centres with hundreds-strong order
Edited by lol-lol
EV weight may be coming down but they are still heavy - eg your 'lightweight' French Renault Scenic is heavier than my 'heavy' German petrol Kodiaq by a margin of around 300kg.
In terms of tyres - yes they are designed to be quiet inside the car - hence the absorbing foam etc... BUT... the drive-by noise rating remains largely the same for similar tyre sizes - eg both the Michelin Primacy 4 and Michelin Primacy-e in 235/50R19 size both have a noise rating of 70dB.
I think you may be seeing what you want to see, as opposed to what is actually being seen?
Groundhog day again. The Councils / Local Authority discussion was done several times here. Location location location. There will be councils where VANS have to do lots of miles in a day, and others that might just be a city and the miles their vehicles might not be so much. Getting BEV,s into the mix is just a case of what the Local Authority is prepared to sort out as far as economics and efficiency and meeting the Net Zero targets that they need to be meeting.
Edited by Evolution13
Please supply the jetb weight of your petrol Skoda ?
Think my Scenic is 1746 kgs kerb weight. Be amazed if it is 300 kgs difference.
70 decibels is on the quietish for any tyre and is measured external in the noise tests as I understand. I have tge nice slim 205/55R19s on my Scenic. Cheapish to replace and its looking like none will need replacing in its 4 year PCP period as wear is so low.
New current version of the Scenic has a minimum of 220 hp, mines 170 hp, so i hope it does wear tyres faster. Even with 67 KWh LFP battery I don't think it weights more than a few Kgs more.
Which engine do you gave in your Skoda ?
