OCTAVIA STARTS BUT WILL NOT RUN.
Hi everyone I was registered on here before under the display name POUCH,  but I've had to do it again as Briskoda would not recognise me!!    Anyway the problem is my son's Octavia starts but will not run,  the maxidot and instrument panel does not illuminate.  The heater fan works as do the lights,  but the thing will not run on after starting it.  We put a electric heater in there as we thought it might be because of the cold weather creating damp,  fuses are all ok we're at a loss to understand what the problem is.  Has anyone on here had the same problem??   Any and all help/suggestions would be gratefully appreciated.   Thanks and regards.  D4KGP.
What engine's in it? How long does it run for after it's started?
Electrical fault in/to instrument panel e.g. loose/oxidized connector, chaffed wire.
Hi its a 1.9 diesel,  runs for about 30/60 seconds
Hi thanks, have you had anything like this happen to you if so what did you do to rectify it.
I haven't, I'm just hypothesising given the info to hand.
Have the car scanned and see what's gleaned.
Start by scanning all the computer modules for fault codes with a tool like VCDS or other equally-capable scan tool.
Post the results of that here and we can try to help further
Hi as I understand it a proper scan can only be done if the engine is running.  Yes or No?
Just needs the ignition to be switched ON to pull any stored fault codes
Surely if it starts but does not run its electrics or fuel
Probably not in this case but if the immobiliser doesnt see the transponder in the key then the engine shuts down after a few seconds, but I believe its only 3 or so seconds. Has the key been opened to replace a battery, sometimes the tiny transponder chip can fall out. Try a spare key.
Can you hear the lift pump running before starting it? I'm unsure whether the 1.9 has one, my 115 Bora did but friends 1.9 100 A4 did not. I know with my PD engine it won't run long without the lift pump working... may be worth checking?
The other thing to consider, when was the fuel filter last replaced ? and there is also a filter inside the lift pump, also the engine code would help, look at the V5 logbook the engine serial number will begin with 3/4 letters that is the code
if no lights on dash then it's definitely electrical, check the canbus module might be wet,
Hi read the original posting.
Hi everyone.  Just to update you all put electric heater in the car to try and remove damp atmosphere,  charged the battery over a couple of days  connected it up yesterday my Son then put the key in and hey presto everything lit up like a Christmas tree!  Turned the key and to our delight and relief engine burst into life,  so at the moment everything is fine.  Thanks to all those who replied to the initial posting.
